diggermandachs
  • 8
Problems with router
Several times this week, the router has lost the internet on wi-fi. When it is rebooted the wi-fi is connected to the internet. This loss of internet also affects our landline and because of poor mobile reception we rely heavily on the landline.
I tried phoning customer services but only got automated messages which tested my system and recommended rebooting the router. I was not given the option to speak to an assistant.
What should I do next?
conman33158
  • 1.43K
  • 124
  • 264
Knows their stuff
Re: Problems with router
Have you tried a full factory reset? Hold in the pinhole at the rear of the router for at least 50 seconds and then release (the lights will flash while holding in the pinhole reset button after about 10-15 seconds) then allow 5 minutes for the router to reboot and re-sync the connection 🙂
Paulina_Z
  • 514
  • 16
  • 33
Hi @diggermandachs,
Welcome back to our Community! We really appreciate you posting again.
We're sorry to hear that you're experiencing some issues with your connection, and apologies about the delayed response.
Would you be able to try the pin-hole reset as @conman33158 suggested, and let us know how you got on? Are you still experiencing this issue?
Keep us updated if you can.
Paulina_Z
diggermandachs
  • 8
Thank you both. I have used the pin hole method and am waiting to see if it works. At the moment everything is fine and working as it should.
