forumarchive,nothingtosee,
brassed01
  • 42
Problems with Mobile phone connection
For about half a day earlier this week I lost with my WiFi and could not sign in. Immediate thoughts were that someone had changed my passwords which had not been changed from new. So I set about changing them which ended with me doing a complete reset of the Router. Have eventually got everything working with TV, Computer, iPad and Printer. Mobile works but not properly, it tries to log on but doesn't latch on completely ( circle rotates as it searches, stops momentarily then rotates again) and WiFi symbol on phone screen has 2 little arrows showing data transfer. I have seen on the internet that lots of people have the same problem. Phone is a Samsung Galaxy A30. Have tried it on 2.4 GHz  and 5 GHz but makes no difference. Router is the Realtek Hub3.
gary_dexter
  • 28.96K
  • 1.77K
  • 3.79K
Re: Problems with Mobile phone connection
Have you split the Wifi bands?
brassed01
  • 42
Have heard that mentioned but don't understand how to do it?
brassed01
  • 42
Did a search and found a copy of the instructions posted back in 2019. Will see how it goes.
brassed01
  • 42
Finally got round to doing the split but made no difference, fortunately still work but phone and ipad looking for another signal. ipad is set for 2.4ghz and phone for 5. Could also switch phone to 2.4 but none of it seems to make any difference. Took ipad to another part of the house with more walls between Router, but no change except it coming up with about 6 alternative connections, presumably house next door and others across the street.
brassed01
  • 42
One thing I forgot about, checked back, the day before I had the problem with my WIFI and router, I got an email from my gas and electricity supplier to say they had resurrected my smart meters which meant I would no longer need to provide readings. Just wondered if that could caused the problem as it obviously works on WIFI and I have read it can interfere and in extreme cases make home WIFI impossible.
