  • 5
Message 1 of 5
Problems throughout
We have detected an issue that maybe affecting your broadband
When I do a test of my equipment the test runs approx 30% then goes to a screen with the above heading. It says they know about it but it’s “complex”. Plus the app joins my devices to the hub3 but it drops out after a short while, telling me someone else is signed in. This is getting SO frustrating because my wifi is often intermittent. Please rescue me!!!
  • 6.51K
  • 490
  • 860
Hero
Message 2 of 5
Re: Problems throughout
Go round all the accessible co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some troubleshooting; to start with …
Then
Can you please
When the page appears DO NOT LOG IN but click ‘Check Router Status’.
Copy and paste the contents of the Downstream, Upstream and Network Log tabs onto here, if you get a yellow warning click the Post button again.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 5
Message 3 of 5
Helpful I’m sure but I don’t understand any of it. I’m not tech at all!!
  • 5
Message 4 of 5
My Wi-Fi is experiencing something “complex “ which I don’t understand. It’s just not being reliable and is interrupting me
  • 3.57K
  • 215
  • 415
Message 5 of 5
Hi there @Dragonsitter
Welcome back to our Community, sorry that you seem to be having some issues with your broadband at the moment. I can see that our Community member @MikeRobbo has offered some assistance with your issue in his reply.
We understand that not everyone is technically minded which is why they (and us) try and offer as much assistance and instruction as possible. He has posted full instructions on how to set up the Broadband Quality Monitor and how to check your Hub stats. We never expect anyone to understand what they mean which is why either one of our more experienced members or staff members will always return back to the thread to help you out and offer any further help and assistance 🙂
However, I have been able to locate your account from your forum information and have been able to take a closer look at your account from here. We can see you are impacted by a known issue called Signal to Noise Ratio (SNR) - this will be causing intermittent issues and potentially speed issues with your broadband. The issue has been logged under reference number F008344039 and the estimated fix date is showing to be 17th September 2020.
I have logged this on your account for your - if you're still having issues after tomorrow, please do pop back and we can check for any updates with the area issue and go from there,. You may find that a reboot can help - we can see it has been around 4 days since the Hub was rebooted.
Cheers
Katie - Forum Team
