Problems connecting to EE website
madasaf1sh
Is anyone else experiencing issues connecting to the EE website at all, as it seems that their incompetent DDOS provider is blocking some VM IP address..
I can see from Wireshark logs Incapsula (Impervia) are redirecting the DNS requests, but trying to get EE to do anything is like pulling teeth
3 REPLIES 3
Hi @madasaf1sh
No problems here on Teesside using my VM broadband.
Dave
The do's and don'ts.
Do a traceroute if you can.
C:\>tracert ee.co.uk
Tracing route to ee.co.uk [45.60.72.23]
over a maximum of 30 hops:
  1    <1 ms    <1 ms    <1 ms  192.168.1.1
  2     *        *        *     Request timed out.
  3    11 ms    19 ms     9 ms  haye-core-2a-ae36-0.network.virginmedia.net [80.3.178.217]
  4     *        *        *     Request timed out.
  5    10 ms    10 ms     8 ms  m686-mp2.cvx1-b.lis.dial.ntli.net [62.254.42.174]
  6     *        *        *     Request timed out.
  7    11 ms    11 ms     9 ms  uk-lon01b-ri1-ae-23-0.aorta.net [84.116.135.30]
  8    11 ms    10 ms    10 ms  213.46.182.188
  9    18 ms    12 ms    16 ms  45.60.72.23
Trace complete.
C:\>
Hub 3.0, TP-Link Archer C8, TP-Link TL-SG108S 8-port gigabit switch, V6
My Broadband Ping - Roger's VM broadband connection
Its not a traceroute issue, nor is it a routing issue with VM, as if I use VPN it works, when i use split tunnelling. It is defo an IP Block..
I know what I am looking at thanks....
The webpage comes up with BLOCKED on a standard html page, and when looking at the TCP logs in Wireshark, I can see the DNS Intecept by Impervia who do the DDOS mitigation for EE.
