Problems after Relocating the Hub
n_glover
An engineer came to the house and relocated the Hub to a bedroom. They used an existing cable on our building that is old but they tested and said it should work. But after they left and relocated the hub, The hub worked at first but now shows a Red Power LED. I tried resetting and restarting it but the Red LED persist. I am still getting internet but not as fast.
After checking the hub settings, it says Internet (Partial Service (US+DS))
331000000
Locked
Ranged Upstream Channel (Hz)
49600263
Locked
Provisioning State
Online
13310000009.538256 qam25
1Locked38.970
14960026342.3512064 qam1
13 REPLIES 13
Legend
Check for a local fault in your street on 0800 561 0061 it is an automated number.
There should be 24 Downstream Channels at least 4 Upstream Channels for a normal Hub 3 connection.
Martin_N
Hi n-glover,
Thank you for your post. I'm very sorry to hear about the issues you've been having.
I have taken a look on our side and it looks as though you have been able to speak with the team regarding this.
Do you require any further assistance?
^Martin
They came and fixed the issue and it worked well for a few weeks. But now I am getting on/off packet loss throughout the day. It might be an area issue as there has been scheduled matinence in my area for the past two weeks. So i thought I would ask on here to find out which one it is.
Hi there @n_glover
I'm so sorry to hear that you are experiencing these issues with your service and welcome back to the forums.
I've taken a look on our side and I cannot see anything that could be causing these issues.
Can you post your Hub status and logs? How to do this;
• Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum
387000000
Locked
49600000
Locked
Provisioning State
Online
26/08/2023 13:16:6Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:16:5Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:15:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:15:53Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:15:47Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:15:45Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:14:16Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:14:13Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:14:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:14:4Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:13:58Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:13:57Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:13:45Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:13:43Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:13:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:13:21Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:11:15Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:11:9Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:11:0Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:10:59Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
26/08/2023 13:10:31Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
https://www.thinkbroadband.com/broadband/monitoring/quality/share/774e89fdd5d26138f5a6f4f64cf047523435d6d2
is the hub still showing one channel for downstream and upstream?
your BQM looks ok I suggest you use modem mode and get a better router with 1Gb ports
Roger_Gooner
Your log shows that your modem is failing to maintain network lock, and when it reconnects it can't get all the channels it should be locking to. You need a tech to come round again with a replacement hub in case it's needed.
Hub 5, TP-Link TL-SG108S 8-port gigabit switch, 360
My Broadband Ping - Roger's VM hub 5 broadband connection
When I check 192.168.0.1 it sometimes says Partial Service(DS only) and in downstream and upstream there is more than one.
