on 19-07-2021 19:02
Getting (short) intermittent disruptions to broadband. The Network Diagnostic Tool acknowledges 'your home network has a few problems' but then just hangs! How do I get past this and talk to a real person?
on 19-07-2021 19:11
on 19-07-2021 19:11
Broadly speaking you aren't supposed to. But if you do, it'll probably be some poor beggar following a rubbish script that they don't understand, from the world's cheapest and least effective offshore call centre.
However, this forum has helpful UK based staff on hand, and an assortment of peasantry such as myself who'll do what we can to help. As a start, connect to the hub by clicking on this link http://192.168.0.1/ 9assuming you're using the hub in router mode). That should pull up the log in page for the hub. But don't log in, just click on the link "Check router status" That'll bring up a window with five tabs. Open the Downstream tab. Select all the text (Ctrl-A if using a keyboard), copy it (Ctrl-C), then paste it (Ctrl-V) into a reply here as TEXT not screenshots. Post that, do the same for the Upstream and Network log. You'll get an error message when you post the Network log, just click on "post" a second time.
Then we can check for any obvious problems with power, noise or error counts.
on 22-07-2021 10:17
Hi @Rayxxx,
I'm so sorry to hear that you've been having some broadband connection issues recently. Are these ongoing for you today? If so, have you checked our Service Status page for any known area impacting faults that may explain this issue that you're facing?
