Message 1 of 5
Problem with wifi
So our internet keeps kicking all of our devices of the wifi.We’ve been sent a news hub which didnt solve the problem.So they sent out a technician to fix problem.This also hasn’t solved the problem.And each time I ring virgin media,you get cut off o can’t even speak to anyone!!
  • 11.36K
  • 888
  • 1.45K
Message 2 of 5
Re: Problem with wifi
What is your connection like using a direct connection using a Cat 5E/6 cable between the Hub and a 1Gbs capable Pc/Mac/Chromebook and no other devices connected ?
Mike Robinson
Retired Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
  • 24.31K
  • 1.39K
  • 3.09K
Message 3 of 5
Are wired connections dropping?
Message 4 of 5
Yes believe it kicking everything off wireless and others
  • 3.93K
  • 234
  • 454
Message 5 of 5
Hi there @Racheyroo
Welcome back to our Community - I was sorry to understand that you're having some issues with your broadband connection even after you had a new hub and technician. I was able to locate your account from your forum information and I can see that you have since contacted us and we have arranged and sent out some Boosters for you.
Have you managed to get these set up and working?
I've taken a look at things from here and I can see that you last rebooted around 5 days ago. We have no know area issues and no errors showing at all this end. All signal levels are showing to be exactly where we would expect them to be for your package and equipment.
Hope things are looking better since your last post - if you're still having issues, please do pop back and let us know.
It may also be helpful to set up a free “Broadband Quality Monitor” to continually monitor the state of your connection and record any network dropouts.  It does it 24/7/365 and it keeps a visual record of your connection. If you need any help with that please let us know.
Cheers
Katie - Forum Team
