Just joined
Problem with connectivity
I recently had a problem with my phone line, the Virgin engineer when visiting said the line was old and it would be a better option to run it through the Hub 3 which he did.
Since then I have had problems in so much as one laptop and my Ring doorbell will not connect to WI FI, the laptop will pick up internet with an Ethernet cable but will not locate the WI FI at all, same with the door bell even when placed next to the Hub.
I have restarted the Hub etc with no luck, I do have quite a few devices, could the phone line be the straw that broke the camels back ??
Any advice appreciated.
  • 11.7K
  • 913
  • 1.51K
Re: Problem with connectivity
Disconnect the phone from the Hub and fee how the problem devices run.
Mike Robinson
Just joined
Thanks Mike, I did already try that to no avail.
  • 24.57K
  • 1.41K
  • 3.12K
Do a 60 second pinhole reset on the hub
