Alex5276
  • 120
Message 1 of 135
Problem Wifi - Logs uploaded - Help
Hello
I have been having multiple disconnections lately with Virgin media. I called support and said they would monitor and call back which they never did. I am now coming onto this forum and pasting my logs. Could you please give me a call and help before I decide to switch ISP.
22/05/2022 16:02:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:01:39criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:57:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:54:36criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:09:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:06:24criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:06:2noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:05:48criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 15:04:34criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:59:25criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:53:48criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:52:28criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:50:4Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:41:15criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:41:6criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:38:15criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:31:33criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 14:24:52criticalSYNC Timing Synchronisation failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 13:45:57Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 09:43:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 20.47K
  • 828
  • 2.2K
Message 2 of 135
Re: Problem Wifi - Logs uploaded - Help
setup a BQM
  • 13.87K
  • 1.07K
  • 2.81K
Message 3 of 135
Also please post a full set of stats. Customer services telling you they will monitor and phone you back is just a way of ending the call and getting rid of you!
Alex5276
  • 120
Message 4 of 135
What other stats do you need? Where can i find them please on the router page?
I have setup a BQM as well.
  • 13.87K
  • 1.07K
  • 2.81K
Message 5 of 135
How to get stats from a VM hub (no need to logon to the hub)
Open a web browser and go to 192.168.0.1 router mode or 192.168.100.1 modem mode
  • Click on the “> Check router status” button
  • Click on the “Downstream” tab, copy the text and paste into your reply, do not take a screen shot
  • Click on the “Upstream” tab, copy the text and paste into your reply
  • Click on the “Networking” tab, copy the text and paste into your reply.
Alex5276
  • 120
Message 6 of 135
1139000000-238256 qam1
2147000000-237256 qam2
3155000000-238256 qam3
4163000000-2.238256 qam4
5171000000-2.238256 qam5
6179000000-2.538256 qam6
7187000000-2.538256 qam7
8195000000-2.538256 qam8
9203000000-2.738256 qam9
10211000000-2.938256 qam10
11219000000-2.733256 qam11
12227000000-2.430256 qam12
13235000000-2.238256 qam13
14243000000-2.538256 qam14
15251000000-2.740256 qam15
16259000000-2.739256 qam16
17267000000-2.738256 qam17
18275000000-338256 qam18
19283000000-2.738256 qam19
20291000000-2.738256 qam20
21299000000-2.538256 qam21
22307000000-2.738256 qam22
23315000000-2.538256 qam23
24323000000-2.538256 qam24
1Locked38.691418003158677
2Locked37.34887199572040
3Locked38.63063501146738
4Locked38.62920804164360
5Locked38.92003347124241
6Locked38.9152734980142
7Locked38.9156750595143
8Locked38.9186059362529
9Locked38.6132891636971
10Locked38.642495726702
11Locked33.3193368837426
12Locked30.85683901082656
13Locked38.97783205477
14Locked38.61769377174
15Locked40.39070811686
16Locked39.3865397067
17Locked38.91167641414
18Locked38.92656851673
19Locked38.975673982
20Locked38.9413341236
21Locked38.927551849
22Locked38.919043866
23Locked38.9207561045
24Locked38.963495898
Alex5276
  • 120
Message 7 of 135
14620000050.8512064 qam3
23939992750.5512064 qam4
33260000050.5512064 qam9
42580000050.3512064 qam10
1ATDMA0040
2ATDMA0090
3ATDMA0050
4ATDMA00100
Alex5276
  • 120
Message 8 of 135
22/05/2022 19:38:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 19:37:38Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 19:35:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 19:33:36noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 19:31:21criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 19:07:17Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 19:01:55noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 17:19:28Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 17:09:26criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 17:06:59Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:59:5ErrorDHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:52:7criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:46:38criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:45:16criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:42:44criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:38:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:19:29criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:17:41Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
22/05/2022 16:03:54criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
g0akc
  • 2.04K
  • 161
  • 386
Problem sorter
Message 9 of 135
The error count is very high.  When was the hub last rebooted?
if it’s a long time ago turn power off/on to reset the counter and post the updated stats.
I know a bit about Wi-Fi, Telecoms, and TV as I used to do it for a living but I'm not perfect so don't beat me up... If you make things you make mistakes!
g0akc
  • 2.04K
  • 161
  • 386
Problem sorter
Message 10 of 135
Also SNR is poor and upstream power is maxed out - suggest you need a VM technician visit
call and be assertive or wait for a forum rep to arrange
