Powershell and DNS/IPv4 issues
Hello,
I am using Powershell a lot at work to access SharePoint. All of a sudden I am getting an error connecting saying DTD issue.
Now after googling it I find this:
  1. Is it a DNS issue? It’s always a DNS issue, isn’t it!
    • Connecting to Microsoft’s datacenters might be trickier than you’d think. Interwebs is filled with stories about Microsoft just returning unresolvable DNS entries, which messes up the script, or your ISP might be trying to help and just makes the issue worse (by offering a “DNS help”-page which just omits the actual exception)
    • This might be fixed with changing to Google’s DNS (8.8.8.8), adding new entries to hosts file, disabling ISP or router features or just simply running the program/script somewhere else – try Azure virtual machine, for example.
  2. It’s not DNS messing up? Then maybe it’s IPv6!
    • This was weird, but disabling IPv6 finally solved our issues
But I don't know how to do this on the Virgin Hub 3
Any help would be good.
  • 6.63K
  • 494
  • 870
Legend
Re: Powershell and DNS/IPv4 issues
Virgin don't use IP V6.
Forgetting the results of your Google search.
Are you at home connecting to work over the internet ?
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
