Powerline Adaptors with Hub 5
BlackMonk30
Dialled in
I currently have powerline adaptors (supplied by Virgin) connected to my Hub 4, which work fine as they did with my Hub 3 prior.
I am currently waiting on delivery of the new Hub 5 and was wondering will the adaptors still work with the Hub 5 ?
4 REPLIES 4
They should, but will need a factory reset to get the new Hub 5 SSID and password setup.
However, they are no longer supported, as VM are now supplying WiFi Pods.  These use wifi to connect to each other and the Hub.  You can then run an ethernet cable from a Pod to your device.  They don't use the house wiring for connections.
spenno73
Mine no longer work since switching from a hub 3 to a hub 5. Not impressed at all wish I had kept the old router as all worked great and only recently bought new adapters 😞
What adapters did you buy that are no longer working?  Most PLA's use ethernet, so they should work with any VM Hub.
Legend
Make sure the power line adaptors are paired & are connecting to each other ( check the LEDs )
Use the powerline manufacturers app / program to check the power line adaptors have connected to each other at a reasonable speed.
If the poweline adaptor is also a WI-Fi access point, make sure that device has an IP in the 192.168.0.xxx range that does not clash with any other device or with the Hub's DHCP allocation range.
