Message 1 of 7
Power level
Hi. Have a superhub 2ac and have done for a while but recently it seems to drop connection every morning.
Power levels
Downstream ChannelsLock Status Channel ID Frequency Modulation Rx Power RxMER Pre RS Errors Post RS Errors
Locked2146750000 Hz256 QAM-13.6 dBmV 33.6 dB5697313
Locked1138750000 Hz256 QAM-13.7 dBmV 33.3 dB12020302
Locked3154750000 Hz256 QAM-13.5 dBmV 33.7 dB3378292
Locked4162750000 Hz256 QAM-13.2 dBmV 34.1 dB1900290
Locked5170750000 Hz256 QAM-13.0 dBmV 34.3 dB703309
Locked6178750000 Hz256 QAM-12.7 dBmV 34.6 dB447291
Locked7186750000 Hz256 QAM-12.6 dBmV 34.8 dB359276
Locked8194750000 Hz256 QAM-12.4 dBmV 34.8 dB418308
Upstream ChannelsLock Status Channel ID Frequency Modulation Tx Power Mode Channel Bandwidth Symbol Rate
Locked160300000 HzATDMA54.0 dBmV64QAM6400000 Hz5120 Ksym/sec
Locked253700000 HzATDMA54.0 dBmV64QAM6400000 Hz5120 Ksym/sec
NotLocked00 Hz 0 dBmV  0 Ksym/sec
  • 11.36K
  • 784
  • 1.6K
Message 2 of 7
Re: Power level
There is too much attenuation on your line, do you gave any attenuators on your hub?
I work for Virgin Media and my posts are my own opinions
  • 6.36K
  • 470
  • 834
Hero
Message 3 of 7
Re: Power level
Check that all your co-ax connectors are a good finger tight.
Then it may be a good idea to carry out a factory reset on the Hub …
With the Hub Powered on use a paperclip or similar do a pinhole reset.
DO NOT reboot the hub but allow it 5 to 10 minutes for it to boot itself up.
Once a steady white and no other lights are illuminated check and post your power levels again again.
A Guru will be along in the not too distant future to decipher the data.
Mike Robinson
Aircraft Engineer & Computer Based Training and Learning Designer for many of the world's Military Arms.
Message 4 of 7
Re: Power level
Nope no attenuators just the splitter for the virgin box. And I will do the powering off the router and check again soon. Thanks
  • 14.81K
  • 1.16K
  • 3.46K
Message 5 of 7
Re: Power level
as said above the levels are wrong - you need a tech to sort that - ring or wait for VM to get here
____________________
Tony
  • 11.36K
  • 784
  • 1.6K
Message 6 of 7
Re: Power level
YUou'll need a tech then to increase the signal to your hub
  • 2.63K
  • 197
  • 266
Message 7 of 7
Re: Power level
Sorry to hear the issues that you've been having Puppetmaster90, as jb66 stated above, you would need an engineer visit to resolve the issues that you've been having with your power levels.
I will send over a private message in a moment, please can you respond to the message with the requested details, so that we can pass account security and look into the issues for you.
Steven_L
