Message 1 of 8
Power cable extension for super hub 3
Hi.  I would like to relocate my superhub 3 to improve WiFi signal through the house. However where I want to put it is 3 metres from the plug socket so I need either an extension cable or a replacement power cable over 3 m long.  I cannot find the specifications so can someone advise what the specification is and the best place to get one.
thanks in advance.
  • 21
Message 2 of 8
Re: Power cable extension for super hub 3
you will probably have to make your own using a male and female 6.3mm dc jack connector on each end. 6.3mm is not a commonly used size.
VM might not be happy with warrenty if you splice extra cable into your psu cable.
  • 7.72K
  • 614
  • 1.32K
Message 3 of 8
Try some searches on Amazon.
Message 4 of 8
Many thanks. Couldn’t find the size anywhere in the specs!
  • 21
Message 5 of 8
LIke I said its an odd size so you wont find a ready made cable
  • 11.56K
  • 825
  • 1.64K
Message 6 of 8
  • 14.75K
  • 620
  • 1.42K
Message 7 of 8
@jb66 wrote:
https://www.amazon.co.uk/Pro-Elec-PL09173-Gang-Extension-white/dp/B00N8W33XI/ref=mp_s_a_1_5?adgrpid=...
Solving a DC problem with AC.
  • 11.56K
  • 825
  • 1.64K
Message 8 of 8
