Just joined
Port forwarding on Hub 4.0
I'm trying to port forward port 80 on my Hub 4.0. My current setting is here (shown in red):
However, the open port checker tool says it is closed. I can access it via localhost, and using the internal IP. I am using the same settings as the Hub 3.0 that I upgraded from. Is this a common problem? I made sure to follow port forward instructions correctly.
Update: The open port checker is now marking it as open, after I forwarded 79-81 instead of 80-80. Shame there isn't a singular port option. However, I still cannot connect, though I can connect via internal IP.
  • 14.81K
  • 622
  • 1.43K
Re: Port forwarding on Hub 4.0
If you can't get it to work then it be best to get your own router with 1Gb ports and use the hub in modem mode.
