Port forwarding not working after switching from hub 2 to hub 3
Port forwarding not working after switching (and re-adding the settings to the new hub) from hub 2 to hub 3, port 80 and 443 (I run a web server), I changed the ISP to point to the new IP address over 24 hours ago, but just not getting through the new hub ? 99% sure it's a hub problem after having run tracert, DNS and ping checks
  • 6.82K
  • 532
  • 1.14K
Legend
Re: Port forwarding not working after switching from hub 2 to hub 3
If you are using the default VM DNS servers updates can take up to 48 hours to be applied. You could try 1.1.1.1 or 8.8.8.8 as DNS servers.
  • 13.29K
  • 528
  • 1.22K
Try the hub in modem mode see if gets traffic to the web server then think about getting your own router with 1Gb ports.
