on 19-11-2023 19:07
I'm not great when it comes to being able sort out Port Forwarding, as I've never had to do this sort of thing before.
I need to open a port say for example 10100.
Truth is I've no idea where to start within the hub, which is a Hub 5.
Any help in this matter would be great.
TIA.
on 19-11-2023 19:42
Should be available here:
You'll need to assign the device you are forwarding the port to a Static IP address under the DHCP section, under reserverd IP addresses:
