  • 15.05K
  • 637
  • 1.46K
Message 61 of 67
Re: Port Forwarding on Hub 3
@bowson wrote:
seems problems are still occurring with SH3. Just received mine today as upgraded to VIVID350 and can't get any port forwarding working, nothing in this thread seems to have helped..
anyone still listening hear that can help?
 If you want to do Port Forwarding use modem mode and get your own router.
Settling in
Message 62 of 67
Hi all,
I'm trying to open up some VPN ports (UDP_500, UDP_1701. UDP_4500) to my Synology server unfortunately no matter what I do, it doesn't work.
I have tried ascending and descending order as mentioned on this forum, I have restarted the router multiple times as well as factory defaulted it unfortunately still no luck.
What does work just fine is the port forward to my NVR (TCP_8000), unfortunately this is the only one which works.
I even tried to open up RDP to my home PC, and while the PC accepts telnet on port 3389 internally, it won't work externally even tho I have only a single port added to the list.
The weird thing is that VPN worked initially when configured maybe for 2-3days and then it stopped. It does work fine when inside of the network so it has to be something to do with this VM box.
Also, as mentioned on this forum, when I disable the firewall, even the TCP_8000 won't work so it has to be enabled.
I can see many of you guys have managed to fix the problem by getting the ports in ascending order so it must be something I'm still missing here...
Any ideas?
Also, is it possible to get the firmware upgraded or it's managed by Virgin remotely?
I have seen some of you were talking about SH3 - what is it?
  • 5
Message 63 of 67
Hi phdmonkey,
I wish I had seen your post before I bought my own router.
Here is my story.
Could not get anyports on the super hub 3 to work except 80-18003, I purchased a new router and put the hub 3 in modem mode.
Forwarded the ports i required on my new router however, they will still not open.
Any idea's?
Cheers in advance.
  • 15.05K
  • 637
  • 1.46K
Message 64 of 67
Ports don't open unless you have a something running on them and UDP can't be scanned reliably to show open.
If you run in modem mode with the device in question and scan for TCP ports and don't show open then its your firewall on your device.
  • 5
Message 65 of 67
Thanks for your reply, I will give this a try and let you know.
Cheers.
Settling in
Message 66 of 67
Hello
I'm trying to port forward Port 53 for Xbox (one) Live but I keep getting this error message next to both end ports:
"The configured port range cannot contain one of the following reserved ports: 25,53,135,137,138,139,161,162,445,1080"
Anyone able to give me any info on this?
Message 67 of 67
Hi phpcodemonkey and anyone else that can help
What if your ports are in the format below:
Internal/local     External
80-80                8008-8008
8000-8000        8000-8000
How do you arrange these as the lower port, as the 1st line's External port is higher than the 2nd lin'e port numbers? Thanks.
