  • 6
Message 21 of 66
Re: Port Forwarding on Hub 3
Fingers crossed, pain to go through customer support again!
  • 7
Message 22 of 66
Unfortunately they sent me the hub 2, not the ac..
Settling in
Message 23 of 66
Two weeks a go I have move to Virgin from Sky,
I have hub 3 and I am having the same issue, port forwarding not working
I have setup port forwarding on the hub for my NAS access.
firewall is on
on port checker getting a error "Reason: Connection timed out. "
on my old sky router I have setup and its worked without problem, but on virgin hub its the same setting but getting the time out error.
is that any way I can check the Router Log?
any help will be appreciated..
  • 6
Message 24 of 66
firewall is on
You can check if the port forwarding is correctly setup using this link: http://www.portchecktool.com/
I had to downgrade the router to 2.5AC to get port forwarding working.
You can access the log once you login to the router I guess. I can see the logs on 2.5 Hub.
  • 13.93K
  • 573
  • 1.32K
Message 25 of 66
If you want it working faster use modem mode get your own router.
BQM, Test for outgoing ports and SSL/L2TP VPN test
Message 26 of 66
Hi all,
I signed up just to share how I solved my problem:
I called technical support and had them set my account to IPv4 instead of IPv6.
That's it. I then factory reset my hub and port forwarding started working again.
I'm on VM in Ireland and have the SuperHub 3 since last week. This is my first IPv6 Internet service. Too bad that VM's implementation breaks port forwarding!!
Nothing against the new standard, I just hope VM fixes IPv6 port forwarding with a firmware update, but for the moment I'm good.
  • 11
Message 27 of 66
how do u disable the firewall for sh3?
  • 11
Message 28 of 66
hi i have done all port forwarding that needs to be done but no luck what so ever. the firewall section on modem first there was three green ticks i have even ticked the fourth box to block ip fragmantation or summa.but no luck  i dont understand why virgin took this hub out and this hub is no use to anyone needing ports opening  anyone with any knowledge plz help me out.
  • 67
Message 29 of 66
Im Amazed VM have not rectified the issues with the new Hub yet,I have been on virgin for around 6 months,
I operate a slightly more complicated home network than most users, But i still believe Firewall & NAT are not really classed as enterprise or even business features imo.
It simply does not work on the new hub, Have them downgrade you too the 2AC.
Has AC Wireless & is Still Gigabit
Cap
  • 11
Message 30 of 66
Thanx been with Virgin for more than 3 years they have shown there's no loyalty so might just go somewhere else. My boys play PlayStation they kept losing there speed and Internet that's why had to go on hub 3 otherwise never had problem with hub 2 except connection.
