on 26-01-2022 18:19
Can someone explain why I'm getting this?
on 26-01-2022 18:21
I'm not sure why the image isn't showing in the post
on 26-01-2022 18:27
Because what you are asking the hub to do is to forward ALL ports between 80 and 443, where as what I suspect you want to do is just forward 80 and 443 to what, I presume, is a web server.
Setup two separate rules one where the range for both source and destination is 80-80, and a second rule where the range is 443-443
on 26-01-2022 18:30
Ah I get you, thank you so much this has resolved the issue 🙂
