Port Forwarding Port Closed on Hub 3.0
Donal1
I've been trying to set up a Minecraft server but I'm running into some issues.
The router we've got is a Virgin Hub 3.0 and I've gotten through practically every other step of the set up bar port forwarding.  I'm absolutely sure i have entered the correct IPv4 address and that im using the right port.
I can join the server using localhost but my friends cannot join using my public IP.
I have used multiple port checkers and they all say the port is closed and no matter what port 25565 is always closed. If anyone can help my problem it would be much appreciated.
9 REPLIES 9
Kain_W
Apologies for any issues faced Donal1,
Welcome to the community.
Can I ask regarding this, is this the only port forward that you have set up?
Regards,
Kain
Hi, sorry for the late reply.
Yes it is the only port forward i have set up.
Your firewall is blocking it.
I've checked both the firewall in my computer and on my router. Both are the right settings
My firewall is off in my router
And I've allowed java as inbound and outbound connections on my pc
Put hub in modem mode
@Donal1 wrote:
<snip>.  My firewall is off in my router
As far as I remember the firewall needs to be on in the Hub as it is needed to do the port forwarding. ?
AdamLow
Can you please bump me when you will get the solution ?
The solution is use modem mode or your device firewall is blocking it
Hero
Is the Minecraft server at 192.168.0.204 being allocated that IP address from the Hub's DHCP Reserved List ?
