  • 13
Message 1 of 8
Poor wifi
I had an upgrade to m200 around 6 months ago all been good now getting less than 100 when I did speed test.Have gone through the testing and says ok.
Virgin can you help please
  • 1.6K
  • 85
  • 220
Superfast
Message 2 of 8
Re: Poor wifi
what is your speed test result when using an ethernet connection?
this will ascertain whether you have a line issue or a wifi issue.
My Broadband Ping - spgray
  • 13
Message 3 of 8
Re: Poor wifi
Hi tried ethernet and non and both around 100
  • 1.6K
  • 85
  • 220
Superfast
Message 4 of 8
Re: Poor wifi
post your router downstream and upstream stats.
  • 24.4K
  • 1.4K
  • 3.1K
Message 5 of 8
Re: Poor wifi
100Mbps on ethernet could mean you're using a CAT5 cable or a 10/100 ethernet device.
  • 13
Message 6 of 8
Re: Poor wifi
Hi cable is as supplied by virgin
  • 24.4K
  • 1.4K
  • 3.1K
Message 7 of 8
Re: Poor wifi
And the laptop or device? What model is it?
  • 1.6K
  • 85
  • 220
Superfast
Message 8 of 8
Re: Poor wifi
the OP said that the speeds had been fine previously
