All those stats are fine and the BQM looks better than mine!
However you are not showing us the Upstream data or the Network logs - post those up too.
TV pixellated? What channels? How is the TV connected - to a VM TV box (which one)? To the internet - ethernet or wifi ?
When you say your speeds are poor - how are you testing that. Can you do it this way....
______________________________________________________________________
Connect a 1GB enabled computer/laptop, with up to date drivers, via a known good and working Cat5e (or better) ethernet cable, directly to the Hub which you have put into “modem mode” (see VM website for “How To”). Test at speedtest.net (not using their App!) to your nearest VM server - try on 2 different browsers.
If they are still low – boot the device into windows safe+networking mode and try again.
There are many posts on here where unknown/flaky software, old network card drivers, corrupted browsers, bad cables or other connected devices are limiting speeds on tests.
Report back what that gets.
