DAZZAG72
  • 7
Poor sound quality using 360 by wifi
Set up 360 on tv in bedroom using WiFi connection
never had any problems
sound is now like a dalek
WiFi connection says good
any ideas why sound is so bad
Corey_C
  • 3.45K
  • 186
  • 271
Re: Poor sound quality using 360 by wifi
Thanks for your post and for reaching out to the Community Forums, DAZZAG72,
How has the sound been since your post? Can you elaborate further on your set up? There should also be a coax connection on the box and how is it connected to the TV?
Cheers,
Corey C
