Javon
Just joined
Poor signal from hub, does not cover the house
Signal from the hub doesn't cover 3 bed house.
Atrocious service wish I  never changed supplier
  • 35.1K
  • 3.41K
  • 6.68K
Re: Poor signal from hub, does not cover the house
Note that if you are new customer and you dont like your connection, then you can cancel the whole package and incur no charges -within your 14 day cooling off period.
But also see this post....
_______________
Do you know if its a wifi only issue (ethernet connections are ok?), if it is - then On a Hub3/4/5, you could first try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings At the same time switch off "channel optimisation/Smart wifi” and “ apply and save the settings. All wifi devices will now need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub users get better wifi performance - so its worth trying - but its still no substitute for getting better kit 🙂
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 20 Mbps/room it’s now called… Wifi Max see.-
https://www.virginmedia.com/wifi-max & https://www.virginmedia.com/broadband/intelligent-wifi
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible it will be £5 or £8 month - you are… and it wont be - just look on the webpage.
If not free to you… you will be charged £8/month (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point (4) A combination of (2,3).
£30-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage.
  • 20.48K
  • 828
  • 2.2K
ISP should never do Wifi unless they do it right which VM will not they might as well give us modems which you can put the hub in can get your own router with 1Gb ports.
Its like buying a ready made PC with 2TB only to find its a HDD its well known the OS on a SSD is better and you think I should not have to get a SSD to put the OS on but the seller say its down to cost.
Adri_G
  • 1.95K
  • 65
  • 124
Hey Javon, thanks for your first post on our help forum and welcome to our community.
We'd love to best help, sorry to hear how you feel about our hub and service due to the poor coverage in your property.
We're able to offer solutions and advice on this issue, could you please let us know how you've been getting on since your last post on Sunday?
Has the advice from our insightful members above helped with your query and have you spoken to our team so far to see how to get it resolved?
Did we already provide with a fix / solution or have you submitted a cancellation due to this issue?
Please, let tell us where you are with this and we're eager to support you.
Adri - Forum Team
New around here?
