  • 52
Poor performance Hub 3
My internet connection is very poor on the hub 3.   My ethernet connections drop very badly and devices such as pS4 alert me to poor internet whilst in game.  Before I was able to get average speeds of 200 mbps now 100 mps.  Independent websites speed checks don't give a consistent  speed either.  Again I have to resort to rebooting my hub on a daily basis.
I won't discuss wi-fi as I am aware of the terrible issues and need to invest in my own wifi router as Hub 3 is totally useless.  My booster keeps disconnecting and I routinely reboot my hub to try to get some connection.  The Virgin apps identifies issues but suggests reboot most of the time without resolving any faults.
  • 52
Re: Poor performance Hub 3
We have detected an issue that maybe affecting your broadband service
What does this mean?
  • This issue is caused by interference on the cabling coming into your home.
  • This will cause intermittent speeds and performance may vary at different times.
  • This is most commonly caused by loose connections plugged into your Hub.
Checks you can do which may resolve your issue
1
2
3
4
Make sure your Hub's power supply is firmly connected to the wall and back of your Hub, check the hub is switched on.
  • 20.96K
  • 1.13K
  • 2.7K
Where are you Ethernet connections going?
To a powerline plug, switch, router or direct to the virgin hub?
  • 52
I located a faulty switch which may have been part of the issue and replaced it. I do have more than 4 ethernet devices e.g. CCTV, pc, Hive...  However, I will investigate more and see if there are anymore issues at my end. Though Virgin Media own tests appear to indicate some issues and the booster has been another source of problem. I am still looking into getting my own wifi router and turn the Virgin hub 3 into modem mode.
