davejs2021
  • 8
Message 1 of 17
Poor connection to network low db power with sync timing issues
My wired and W-iFi connections constantly drop using a Hub3.
Reading other users posts about the "SYNC Timing Synchronization failure - Loss of Sync" logs, I too have the same issue:
What is the cause?  It's a real nuisance and telephone support say all is well.  It's definitely not:
Time
Priority
Description
05/07/2021 12:11:3
notice
LAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
03/07/2021 23:00:52
Warning!
RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 16:48:33
Warning!
Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 15:04:5
Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
02/07/2021 09:57:10
critical
01/07/2021 19:23:34
Warning!
01/07/2021 18:18:11
notice
NOTICE ATOM is restarted as part of Self Healing Mechanism;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
29/06/2021 04:24:21
critical
29/06/2021 03:04:5
Error
28/06/2021 14:51:22
notice
25/06/2021 15:04:5
Error
25/06/2021 08:55:55
critical
24/06/2021 01:52:14
Warning!
23/06/2021 16:27:41
Warning!
23/06/2021 16:27:36
Warning!
23/06/2021 16:27:34
Warning!
23/06/2021 13:51:39
Warning!
22/06/2021 03:04:5
Error
19/06/2021 17:58:46
critical
18/06/2021 14:34:5
Error
1202750000-6.938256 qam9
2138750000-7.936256 qam1
3146750000-7.436256 qam2
4154750000-737256 qam3
5162750000-737256 qam4
6170750000-7.437256 qam5
7178750000-737256 qam6
8186750000-6.737256 qam7
9194750000-6.937256 qam8
10210750000-6.737256 qam10
11218750000-6.538256 qam11
12226750000-6.738256 qam12
13234750000-6.937256 qam13
14242750000-7.537256 qam14
15250750000-7.237256 qam15
16258750000-7.437256 qam16
17266750000-7.437256 qam17
18274750000-7.537256 qam18
19282750000-7.437256 qam19
20290750000-7.437256 qam20
21298750000-7.237256 qam21
22306750000-7.237256 qam22
23314750000-7.237256 qam23
24322750000-7.537256 qam24
1Locked38.9367216
2Locked36.114553670871587394
3Locked36.618569119367318
4Locked37.6588228
5Locked37.6525023
6Locked37.3513317
7Locked37.6485612
8Locked37.343125
9Locked37.6426319
10Locked37.630839
11Locked38.6307658
12Locked38.6291018
13Locked37.623694
14Locked37.324880
15Locked37.624151
16Locked37.921890
17Locked37.620120
18Locked37.619490
19Locked37.619010
20Locked37.618310
21Locked37.619630
22Locked37.617810
23Locked37.616390
24Locked37.620260
  • 23.79K
  • 2.52K
  • 4.31K
Message 2 of 17
Re: Poor connection to network low db power with sync timing issues
Can you post the upstream data too but before that can you reset the RS errors to 0 by doing the below.
that said your down power levels are all outside of the recommended range -6dBmV being the minimum. And postRS errors are suggesting a noise issue that will need a tech visit
___________
Switch the Hub off and unplug it for a few minutes and then start up. When done, check back in the settings and ensure that the RS error counts have all reset to 0. Then check every hour or two to see if they start reappearing - they shouldn't. If they do (particularly the postRS ones) you have a problem (noise) that only a Tech visit will sort.
davejs2021
  • 8
Message 3 of 17
Hi John,
Thank you for responding.  I have followed your steps and although the RS port errors have reset to 0, the DB is still low.  Please see updates below:
ime
Priority
Description
06/07/2021 11:42:10
notice
06/07/2021 03:04:5
Error
05/07/2021 17:06:3
critical
05/07/2021 13:03:49
notice
05/07/2021 12:53:53
critical
05/07/2021 12:44:13
Warning!
05/07/2021 12:11:3
notice
03/07/2021 23:00:52
Warning!
02/07/2021 16:48:33
Warning!
02/07/2021 15:04:5
Error
02/07/2021 09:57:10
critical
01/07/2021 19:23:34
Warning!
01/07/2021 18:18:11
notice
29/06/2021 04:24:21
critical
29/06/2021 03:04:5
Error
28/06/2021 14:51:22
notice
25/06/2021 15:04:5
Error
25/06/2021 08:55:55
critical
24/06/2021 01:52:14
Warning!
23/06/2021 16:27:41
Warning!
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
1
202750000
-7
37
256 qam
9
2
138750000
-8
36
256 qam
1
3
146750000
-7.5
36
256 qam
2
4
154750000
-7.2
37
256 qam
3
5
162750000
-7.5
37
256 qam
4
6
170750000
-7.7
37
256 qam
5
7
178750000
-7.2
37
256 qam
6
8
186750000
-7.2
37
256 qam
7
9
194750000
-7.2
37
256 qam
8
10
210750000
-7
37
256 qam
10
11
218750000
-6.9
37
256 qam
11
12
226750000
-7
37
256 qam
12
13
234750000
-7.2
37
256 qam
13
14
242750000
-7.7
37
256 qam
14
15
250750000
-7.5
37
256 qam
15
16
258750000
-7.5
37
256 qam
16
17
266750000
-7.5
37
256 qam
17
18
274750000
-7.5
37
256 qam
18
19
282750000
-7.5
37
256 qam
19
20
290750000
-7.7
37
256 qam
20
21
298750000
-7.4
37
256 qam
21
22
306750000
-7.5
37
256 qam
22
23
314750000
-7.4
37
256 qam
23
24
322750000
-7.5
37
256 qam
24
Channel
Locked Status
RxMER (dB)
Pre RS Errors
Post RS Errors
1
Locked
37.6
21
0
2
Locked
36.3
4818
0
3
Locked
36.6
15
0
4
Locked
37.6
14
0
5
Locked
37.3
9
0
6
Locked
37.3
10
0
7
Locked
37.6
26
0
8
Locked
37.6
21
0
9
Locked
37.6
23
0
10
Locked
37.3
7
0
11
Locked
37.6
7
0
12
Locked
37.6
9
0
13
Locked
37.6
9
0
14
Locked
37.6
5
0
15
Locked
37.6
9
0
16
Locked
37.6
11
0
17
Locked
37.6
9
0
18
Locked
37.6
8
0
19
Locked
37.6
9
0
20
Locked
37.6
7
0
21
Locked
37.6
9
0
22
Locked
37.6
6
0
23
Locked
37.6
8
0
24
Locked
37.6
5
0
So with the above information, would you suggest a VM engineer visit?
Thanks in advance.
Dave
davejs2021
  • 8
Message 4 of 17
More info
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
25800015
46.5
5120
64 qam
8
2
46200000
46.5
5120
64 qam
5
3
39400000
46.3
5120
64 qam
6
4
32600000
46.3
5120
64 qam
7
lotharmat
  • 2.54K
  • 188
  • 458
Trouble shooter
Message 5 of 17
Downstream power is too low - SHould be between -6 and +10 dBmV
VM will need to arrange an engineer to rectify! - They should pick this up soon!
  • 23.79K
  • 2.52K
  • 4.31K
Message 6 of 17
May be quicker to call CS and point out the errors
  • 3.16K
  • 248
  • 685
Message 7 of 17
Also check if you have any attenuators fitted in the circuit?  If so remove it and re-check the power levels.
davejs2021
  • 8
Message 8 of 17
The us no attenuator but there is a splitter.  This is 4.5db on each channel so shouldn't effect the low power.
  • 8.45K
  • 674
  • 1.51K
Message 9 of 17
A splitter like that will certainly affect the downstream power levels.
davejs2021
  • 8
Message 10 of 17
Thank you, yes, one goes to the router and the other to the Virging Media Tivo unit... I'm assuming that all installs are this way or is just mine?
