on 26-09-2023 22:45
I am having issues with my poor WiFi signal. I’ve ran the diagnostics and in the main room where the hub is everything is fine. Move to the next room and the signal changes to fair and poor. Upstairs in the bedrooms we are getting the same poor signal. Sometimes no signal at all!!
How am I able to get a WiFi pod? Also if this solves the problem downstairs what can I do about signal upstairs??? Any help would be gratefully appreciated!!!
Thanks in advance!
Answered! Go to Answer
on 27-09-2023 14:51
Just to expand - see this for info...
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - you are - it is clearly stated on the webpage.
If not free to you… you will be charged £8/month for up to 3 pods (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point, (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
£40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
on 27-09-2023 10:31
This could be good time to invest in a suitable WI-Fi network or MESH that covers you property and your needs.
on 27-09-2023 14:51
on 29-09-2023 15:40
Hey @iamsarat,
Welcome to the Community Forums and thanks for the post.
Sorry to hear you are having issues with your WIFI Signal, I would like to go about looking into this with you and checking into ordering a Pod for you if you would like.
For me to do so I will need to confirm some information from you in a private message.
Joe
