on 20-05-2023 13:58
we have a smart tv in the lounge, the wifi signal to it is not very good and we have to use a devolo wifi extender to get a good reception , we want to put a tv in the back room but there is virtually no wi fi reception there, the Virgin technician who came to fit our hub 5 said we could do with a mesh system ?, has anyone used one and if so how good is it ?
many thanks
Answered! Go to Answer
on 20-05-2023 14:24
VM supply "Pods" are their version of a Mesh system. Depending on your Contract, they are free or £8pm rental.
https://www.virginmedia.com/help/wifi-max- Wifi Pod information
However, there are other Mesh systems on the market, have a look at the Deco M series, as a lot of users here have them.
on 20-05-2023 14:24
on 20-05-2023 19:56
Thankyou for taking the time to reply, just looking at some other posts and they say you should be able to get WiFi in every room so I think I will contact virgin and ask about the pods you have mentioned.
on 20-05-2023 20:16
You can try to ask VM customer services but chances of you getting a pod is slim. Best bet is wait for one of the admin team to pick up this thread. What BB package are you on? As mentioned above, if you are on the lower tariffs then it could get a little expensive to have a pod
on 23-05-2023 10:04
Hi Blemm,
Thanks for posting on our Community Forums about your poor WIFI signal, sorry if it's been causing some inconvenience for you!
Our WIFI Pods are our kind of "mesh system" which can improve your WIFI signal and speed if it's below 20mbps in a certain room. They are free if you're on our top packages or £8 per month on any others. There is loads more information about our WIFI Max scheme here if you want to have a read about what it entails 😁
If you're already up to speed with what WIFI Max is and want to go ahead and order your first pod, you'll first need to go onto our Connect App and do a scan of all rooms in your home. This will detect any issues with WIFI in these rooms and give you prompts on how to fix it - One of these would be to order a WIFI pod if it detects a WIFI issue 😊
Please let us know how you get on with the Connect App so we can continue to help if you need us!
Megan_L
