Qwerty119
Poor WiFi - signal issues and dropouts
I’m having real issues with WiFi, the WiFi speeds are sometimes really low and intermittent. I’m thinking about investing into some sort of WiFi mesh network or router system, not really sure what I’m doing to be entirely honest. Would like some opinions on how to upgrade/improve my WiFi in my house. I’ve had virgin media technicians come over and they can’t find any issues with my WiFi. My router is placed in the middle floor of the house, can’t seem to get range connection in the kitchen downstairs and other parts of the house. I’m hoping to either install a mesh system or put the router in modem mode and use a better route.
tehwolf
  • 1.62K
  • 263
  • 393
Superfast
Re: Poor WiFi - signal issues and dropouts
The two brands I would consider if i were in the market are probably ASUS and TP-Link.. Netgear could be considered alongside them, though I've never been a fan of their products..
The biggest consideration with a mesh is whether you buy a dual-band or tri-band system.. tri-band is more expensive as it includes an additional radio that is dedicated to backhauling traffic between mesh points.. dual-band ones will share the radio that all of your devices use.. whether or not that impacts performance is really down to how many devices you plan to connect to the mesh.
Wifi-6 is only really relevant if you have wifi-6 capable clients. If most of your devices are only AC, then it won't make any difference whatsoever, but you may want to consider it for futureproofing.. whatever you buy should last a few years at least..
Make sure whatever you buy has gig ethernet ports (rather than 10/100) else you'll limit the speed of the connection to 100mb.
Options in the TP-Link range are the M4 (entry-level) M5 (step up from the m4, but still dual band) or M9 (tri-band).. These are all AC devices.  If you want to go for wifi-6 then consider the X20 or X60.
For ASUS, the options are somewhat more varied - many of their devices now support their "AI-Mesh" so you can buy a regular ASUS router (like the one you mentioned in your first post) and then add a separate access to the mesh at a later date.. or you could consider their specific mesh procuts - the premium wifi-6 product being the "ASUS ZenWiFi AX Whole-Home Tri-Band" or for regular AC the "AC3000 Tri-band Whole-Home Mesh WiFi System"
any of the options above are likely to serve you well..
