Poor WiFi even with booster
Hi I have recently had an extention. Built now even with a booster I can’t get WiFi in the extention also the WiFi is pretty crap in the rest of the house
the engineer suggested Cisco but I’ve also seen net gear
has any one used either cam anyone help
  • 24.77K
  • 1.43K
  • 3.15K
Re: Poor WiFi even with booster
A mesh system would work or run an Ethernet cable and install a wired access point
Thankyou so net gear is ok
  • 11.9K
  • 927
  • 1.53K
Netgear is a very good reputable make.
Mike Robinson
  • 24.77K
  • 1.43K
  • 3.15K
In what respect?
Anonymous
Not applicable
Netgear are OK, The Prosafe range is my preferred option if using Netgear, but before you do anything, lets look at the basics.
1. On what band are you getting a poor signal, 2.4GHz or 5.0GHz?
2. How are you measuring the signal?
3. Where is your router sited (Is it in a location clear of obstruction etc?
4. Whats the wifi environment like? (Other networks, baby monitors, Microwave ovens, nearby airports etc).
5. What channels are you using? Have you tried changing them?
6. Before considering Netgear, there are other better options available in a similar price range. BUT lets look at the basics before we spend any money 🙂
I would avoid Mesh networks unless you have to, the problem with bad wifi is seldom made better with more wifi 😉 A wired access point in the other part of house would be infinitely better. Preferably with ethernet cable, but in a pinch, Powerline/Homeplug adapters (that use your houses electrical wiring) will give a more stable signal than wifi.
