BrownerPJ
Poor WiFi and LAN
Just had the 500MB package installed. Great service from the people doing the job.
Hub 3 in the front room. WiFi sitting in front 370MB down/30MB up. This is good but not what’s sold...
Stand about 10m away direct line of site. WiFi 16MB down/7MB up. I think this is terrible. Haven’t even gone outside the same room as the hub yet...
Room directly above the hub 200MB down/20MB up. Anywhere else in the house can’t find the WiFi.
Cat5 cable from the hub into a TP-Link router in the garage (40m away) 70MB down/ 35MB up. WiFi 7MB down/15MB down. Ok given hardware but could be better...
BT non-fibre broadband before this had no problem. 70MB down/ 17MB up WiFi and LAN around the house, garage and garden.
Thoroughly disappointed in performance.
Any suggestions?
apcyberax
  • 33.37K
  • 1.87K
  • 5.93K
Re: Poor WiFi and LAN
that is 100% what is sold,
What speeds do you get wired. VM do not guarantee any wifi connection or speed
