Message 1 of 5
Poor Connection
Hi, for the past few days i have been experiencing a very poor connection, wired and wi-fi, the speed itself will change from 90-100mbs, 40-50mbs and sometimes even 10mbs and below all within minutes of checking the speed each time.
i Have set up a quality monitor for now and have checked the router status, the only thing that jumps out to me is the upstream channels is only 1, should it not be 4 ?
On the M100 package using a Hub 3 in router mode, wifi disabled and using a Deco M5 for wifi needs.
any help would be appreciated.
330750000
Locked
Ranged Upstream Channel (Hz)
46199993
Locked
Provisioning State
Online
1330750000-0.740256 qam25
2258750000040256 qam16
3266750000040256 qam17
4274750000-0.240256 qam18
5282750000-0.240256 qam19
6290750000-0.240256 qam20
7298750000-0.240256 qam21
8306750000-0.740256 qam22
9314750000-0.740256 qam23
10322750000-0.940256 qam24
11370750000-240256 qam26
12378750000-240256 qam27
13386750000-240256 qam28
14394750000-2.240256 qam29
15402750000-2.440256 qam30
16410750000-2.740256 qam31
17418750000-3.240256 qam32
18426750000-3.740256 qam33
19434750000-440256 qam34
20442750000-440256 qam35
21450750000-3.940256 qam36
22458750000-3.940256 qam37
23466750000-4.240256 qam38
24474750000-4.240256 qam39
1Locked40.950
2Locked40.950
3Locked40.950
4Locked40.940
5Locked40.960
6Locked40.960
7Locked40.3190
8Locked40.960
9Locked40.3190
10Locked40.9200
11Locked40.3120
12Locked40.370
13Locked40.3190
14Locked40.350
15Locked40.360
16Locked40.3190
17Locked40.3140
18Locked40.350
19Locked40.350
20Locked40.950
21Locked40.950
22Locked40.340
23Locked40.350
24Locked40.300
14619999349.3512064 qam1
Message 2 of 5
Re: Poor Connection
16/11/2020 11:01:21noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 11:01:9Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
16/11/2020 10:53:18noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:57Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 18:17:28noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
15/11/2020 18:17:19Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 23:27:48noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:42:12noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:41:24criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 22:39:28noticeReceived REG-RSP while in REG-HOLD1 state;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:58Warning!ToD request sent - No Response received;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 19:52:27noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 15:50:30Warning!Lost MDD Timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 15:50:25criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 15:50:24Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 15:50:24criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 15:50:9Warning!RCS Partial Service;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 02:42:9criticalReceived Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
14/11/2020 02:41:22criticalSYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 3.62K
  • 214
  • 276
Message 3 of 5
Re: Poor Connection
Hi Jimm1,
Thanks for posting and welcome to our community 🙂
I'm sorry to see you're having some issues with the connection.
I've been able to locate your account using your forum details, and can see that you're currently affected by an area SNR outage.
The estimated fix time for this is 25th November, whilst this is ongoing you may find your services are intermittent.
Please let us know how you get on after this date.
Alex_Rm
Message 4 of 5
Re: Poor Connection
Thanks for the reply, I will keep monitoring and will respond back if the problem persists after the mentioned date, thanks again got the reply.
  • 3.62K
  • 214
  • 276
Message 5 of 5
Re: Poor Connection
No worries at all 🙂
Keep us posted.
Alex_Rm
