  • 5
Message 1 of 8
Poor Broadband Speed and Non-Existent Wifi
Hi All,
I've been having some issues with my Virgin media HUB3 for the past couple of months. There has been a clear step change in the broadband speed and I can no longer use wifi throughout my house as it keeps dropping out and speeds are >1MBPs. This has only been the case for about 5 months but I have finally cracked!
I previously called support (around 2 months ago) and they informed me that there was some issues with my downstream channels and they helped me to update them. Despite this my internet woes continue and I am convinced that there is a issue with my HUB3. I used to have a wifi booster just to ensure my wifi reaches the corners of the house. This no longer works as there is a "Dynamic IP Failure" (I presume this is because of the router? Either way the wifi without the extender is still terrible).
I have read some of the other forum posts and noticed technicians asking for 2 pages of Downstream and 2 pages from Upstream and the Network logs page. I'll attach this in a reply to this original post.
  • 14.78K
  • 622
  • 1.42K
Message 2 of 8
Re: Poor Broadband Speed and Non-Existent Wifi
Is the connection fine by wire to the hub?
  • 5
Message 3 of 8
NOTE: I have removed MAC addresses included in the network log as request in a post I read previously
DOWNSTREAM
1323000000-5.738256 qam24
2203000000-3.238256 qam9
3211000000-3.538256 qam10
4219000000-3.738256 qam11
5227000000-438256 qam12
6235000000-4.238256 qam13
7243000000-4.538256 qam14
8251000000-4.738256 qam15
9259000000-4.938256 qam16
10267000000-4.738256 qam17
11275000000-4.738256 qam18
12283000000-538256 qam19
13291000000-5.438256 qam20
14299000000-5.238256 qam21
15307000000-5.438256 qam22
16315000000-5.538256 qam23
17363000000-6.938256 qam25
18371000000-7.238256 qam26
19379000000-7.438256 qam27
20387000000-8.238256 qam28
21395000000-8.738256 qam29
22403000000-8.738256 qam30
23411000000-8.438256 qam31
24419000000-8.738256 qam32
1Locked38.96560
2Locked38.91740
3Locked38.62060
4Locked38.92350
5Locked38.63240
6Locked38.63580
7Locked38.65050
8Locked38.65370
9Locked38.95380
10Locked38.96030
11Locked38.94660
12Locked38.97450
13Locked38.66090
14Locked38.64870
15Locked38.64380
16Locked38.65510
17Locked38.615850
18Locked38.918270
19Locked38.619850
20Locked38.627050
21Locked38.936260
22Locked38.633230
23Locked38.625920
24Locked38.625770
UPSTREAM
14620029845.8512064 qam3
23940004945.5512064 qam4
35370029746.5512064 qam2
46030029746.5512064 qam1
3ATDMA0010
4ATDMA0010
NETWORK LOG
21/11/2020 23:03:46notice
LAN login Success;CM-
VER=3.0;
21/11/2020 23:03:23Warning!
LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-
VER=3.0;
21/11/2020 21:05:49criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
20/11/2020 13:59:2Error
DHCP RENEW WARNING - Field invalid in response v4 option;CM-
VER=3.0;
18/11/2020 00:31:38criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
17/11/2020 01:59:1Error
VER=3.0;
17/11/2020 01:27:57critical
17/11/2020 01:27:16critical
Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-
VER=3.0;
17/11/2020 01:22:10Warning!
Lost MDD Timeout;CM-
VER=3.0;
17/11/2020 01:22:5Warning!
RCS Partial Service;CM-
VER=3.0;
17/11/2020 01:22:5critical
SYNC Timing Synchronization failure - Loss of Sync;CM-
VER=3.0;
VER=3.0;
SYNC Timing Synchronization failure - Loss of Sync;CM-M
VER=3.0;
VER=3.0;
01/01/1970 00:01:38criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
14/11/2020 07:10:38ErrorDHCP RENEW sent - No response for IPv4;CM-VER=3.0;
01/01/1970 00:01:39criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
08/11/2020 19:53:11Error
DHCP REBIND WARNING - Field invalid in response;CM-
-VER=3.0;
08/11/2020 06:42:32ErrorDHCP RENEW sent - No response for IPv4;CM-VER=3.0;
07/11/2020 20:50:30criticalNo Ranging Response received - T3 time-out;CM-VER=3.0;
  • 5
Message 4 of 8
Hi Alessandro, thanks for the quick response. The wired connection speed is a bit hit and miss, right now (non-peak) I am getting the full speed, where as early I was only getting 30% of the speed I pay for (this was around 7pm GMT).
  • 24.97K
  • 1.44K
  • 3.18K
Message 5 of 8
Your downstream power levels are too low.
Is there an attenuator fitted to the back of the hub?
  • 5
Message 6 of 8
There’s no attenuator connected in the back of the hub, the white screw in cable just connects straight into the box in the wall.
  • 5
Message 7 of 8
Any advice to resolve this issue?
  • 12.13K
  • 942
  • 1.55K
Message 8 of 8
This will need an engineer to put right.
You can either call in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
