on 21-05-2023 09:27
Yesterday I had my hub5 replaced. I have 2 pods that appear to have stopped working. Do the pods have to be reconfigured to work with the new router or should they just work ?
on 21-05-2023 09:42
I gather the pods need to be programmed to work with your specific hub - VM should be able to sort that out online - if a technician replaced your hub they should have registered the pods to it.
If someone tried to a sell a pod it wouldn't be any good as it would not work with their equipment.
on 22-05-2023 15:47
pods sorted.
next problem: how do i get the connect app to see my new hub5. was working perfectly with my old hub
on 24-05-2023 16:09
Hi @jess67
Welcome to the community forums,
Glad to hear that you have your pods sorted now.
In regards to the connect app pairing with your new hub, can clearing the cache/cookies form the app and can you also try deleting the app and reinstalling to see if this resolve this issue.
