Pod not connecting
JohnH1819
I installed a Hub 5 yesterday but the pod I have will not connect and so signal is now poorer in the rooms I obtained the pod for in the first place.
Advice please.
5 REPLIES 5
As you have a new Hub it needs pairing to the Pod in your account - that may not have happened yet - so call the equipment activation number on - 0800 953 9500 (follow options) and check with them. You will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of Hub and pod and also your account number
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
Zoie_P
Hi @JohnH1819
Thanks for your post and welcome to forums 👋
I am so sorry to hear you are having these issues, I can see you have not reached out to the team since your post. We can take a look into this for you. I will pop you over a PM just keep an eye out for the little envelope 📩👀
Zoie
thanks. I will look out for it but am a complete novice re these types of communication and the associated jargon.
Thanks for coming back to us JohnH1819, the private message should be with you now.
If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox.
If you are on a mobile/tablet device then click on the little circle icon in the top right  and then select 'Messages'.
Kind Regards,
Steven_L
Glad to hear that your pods back up and running 👍
Please let us know here on the forums, if you have any further issues.
Kind Regards,
Steven_L
