on 17-10-2023 11:27
Hi I received a new hub 5 last week. The hub is working fine but my wifi pod doesnt connect to it. I have called 3 times now and I am getting nowhere. Yesterday I called and the person I spoke to said I needed a new pod. I have looked on this forum and don't believe I need a new pod. Can you please link my pod to the hub 5?
on 17-10-2023 13:26
It may not have been activated correctly onto your account.
Call the equipment activation number on - 0800 953 9500 (option 3) – you will need the Model numbers, serial numbers/MAC addresses off the barcode stickers of ALL pieces of kit and also your account number
on 17-10-2023 13:58
I have spoken to them 3 times they havent fixed it.
on 17-10-2023 14:49
Mmm... is it a new pod or one that you were using fine previously ?
on 17-10-2023 15:00
I have had it for over a year it worked fine with the hub3 but since I changed my package to gig1 they sent me the hub5 and it hasnt worked since then and when I go on the connect app its not working on there either.
on 17-10-2023 15:06
Hi Jakelly,
Thanks for posting and sorry to hear you've been having some issues with the pods.
I can see from our side you've been able to speak to us regarding this, so I can go through things in more detail I've popped you over a private message.
Alex_Rm
on 21-10-2023 12:28
Hi Jakelly,
Thanks for joining me over private message, glad I was able to help 🙂
Alex_Rm
