on 08-09-2023 22:13
Hi everybody 👋, I'm having a nightmare and would really appreciate any help resolving this.
I am a long-term Virgin customer, who has had fiber (Broadband only, no phone/tv) for years. Over the past few weeks, I am having the internet drop out multiple times a day, causing me to disconnect from calls, games and disrupt browsing the web. It is getting worse and it is at a stage now where I cannot do anything which requires a constant connection as it will drop and kick me off. Dropouts last from 5 seconds - 30seconds each time. I am now unable to work from home as Teams calls are impossible due to VPN dropping in and out because of this..
This happens with ethernet connections AND Wi-Fi.
I have a Super Hub 4 (M500Mbps). I do get the expected 500 Download and 50+ Upload.
I have been checking from known service issues in my area/postcode daily, there are none.
I have setup broadband quality monitoring (BQM) and it shows severe packet loss. -> https://www.thinkbroadband.com/broadband/monitoring/quality/share/767c855ebfe3649250ca08653c403a2b5f...
I have seen some members share their up/downstream data to help with diagnosis, please find in comments below (character limits)
Fri 08/09/2023 17:00:22 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 1; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 08/09/2023 16:44:46 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 08/09/2023 16:44:46 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 08/09/2023 16:44:29 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 08/09/2023 14:49:57 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 29; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 08/09/2023 14:49:45 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 08/09/2023 10:20:06 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 07/09/2023 12:35:43 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 07/09/2023 12:35:43 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 07/09/2023 07:29:29 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 16:46:09 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 16:46:09 | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 16:45:53 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 16:13:54 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 13:23:29 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 12:57:31 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 12:57:30 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 06/09/2023 09:12:15 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 05/09/2023 19:55:02 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 20; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 05/09/2023 19:54:59 | 3 | SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 05/09/2023 13:26:21 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 05/09/2023 10:13:50 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 20; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 04/09/2023 17:44:22 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 04/09/2023 12:55:21 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 03/09/2023 02:28:29 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 03/09/2023 00:57:30 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 03/09/2023 00:57:30 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 02/09/2023 19:22:54 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 31/08/2023 03:46:09 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 30/08/2023 12:57:30 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 30/08/2023 12:57:30 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 27/08/2023 04:59:23 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 27/08/2023 00:57:30 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sun 27/08/2023 00:57:30 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 24/08/2023 11:03:23 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 24/08/2023 08:48:12 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Thu 24/08/2023 08:48:11 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 23/08/2023 18:41:37 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 23/08/2023 14:32:39 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 23/08/2023 04:08:21 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 22/08/2023 13:30:02 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 22/08/2023 13:29:45 | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 22/08/2023 02:12:31 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Mon 21/08/2023 15:46:22 | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 19/08/2023 18:10:32 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 19/08/2023 04:06:11 | 6 | DHCP Renew - lease parameters tftp file-cmreg-vmdg640-bbt053-b.cm modified;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Sat 19/08/2023 04:06:11 | 4 | DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Fri 18/08/2023 05:01:33 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Wed 16/08/2023 09:51:57 | 6 | CM-STATUS message sent. Event Type Code: 5; Chan ID: 27; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Tue 15/08/2023 19:08:07 | 3 | No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1; |
Many Thanks! 😢
on 08-09-2023 22:15
25 | 330750000 | 5.9 | 40.4 | QAM256 | 25 |
1 | 138750000 | 3.3 | 38.6 | QAM256 | 1 |
2 | 146750000 | 3.3 | 39 | QAM256 | 2 |
3 | 154750000 | 3.6 | 39 | QAM256 | 3 |
4 | 162750000 | 3.8 | 39 | QAM256 | 4 |
5 | 170750000 | 3.8 | 39 | QAM256 | 5 |
6 | 178750000 | 3.9 | 39 | QAM256 | 6 |
7 | 186750000 | 4.1 | 38.6 | QAM256 | 7 |
8 | 194750000 | 4.2 | 39 | QAM256 | 8 |
9 | 202750000 | 4.2 | 39 | QAM256 | 9 |
10 | 210750000 | 4.3 | 39 | QAM256 | 10 |
11 | 218750000 | 4.4 | 38.6 | QAM256 | 11 |
12 | 226750000 | 4.3 | 38.6 | QAM256 | 12 |
13 | 234750000 | 4.2 | 39 | QAM256 | 13 |
14 | 242750000 | 4 | 40.4 | QAM256 | 14 |
15 | 250750000 | 4.1 | 40.4 | QAM256 | 15 |
16 | 258750000 | 4.2 | 40.4 | QAM256 | 16 |
17 | 266750000 | 4.3 | 40.4 | QAM256 | 17 |
18 | 274750000 | 4.2 | 40.4 | QAM256 | 18 |
19 | 282750000 | 4 | 40.4 | QAM256 | 19 |
20 | 290750000 | 4 | 40.9 | QAM256 | 20 |
21 | 298750000 | 4.4 | 40.4 | QAM256 | 21 |
22 | 306750000 | 4.9 | 40.9 | QAM256 | 22 |
23 | 314750000 | 5.5 | 40.4 | QAM256 | 23 |
24 | 322750000 | 5.8 | 40.4 | QAM256 | 24 |
26 | 338750000 | 5.8 | 40.4 | QAM256 | 26 |
27 | 346750000 | 5.5 | 40.9 | QAM256 | 27 |
28 | 354750000 | 5.5 | 40.9 | QAM256 | 28 |
29 | 362750000 | 5.2 | 40.4 | QAM256 | 29 |
30 | 370750000 | 5 | 40.4 | QAM256 | 30 |
31 | 378750000 | 4.9 | 40.4 | QAM256 | 31 |
25 | Locked | 40.366287 | 0 | 0 |
1 | Locked | 38.605377 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 38.983261 | 0 | 0 |
4 | Locked | 38.983261 | 0 | 0 |
5 | Locked | 38.983261 | 0 | 0 |
6 | Locked | 38.983261 | 0 | 0 |
7 | Locked | 38.605377 | 0 | 0 |
8 | Locked | 38.983261 | 0 | 0 |
9 | Locked | 38.983261 | 0 | 0 |
10 | Locked | 38.983261 | 0 | 0 |
11 | Locked | 38.605377 | 0 | 0 |
12 | Locked | 38.605377 | 0 | 0 |
13 | Locked | 38.983261 | 0 | 0 |
14 | Locked | 40.366287 | 0 | 0 |
15 | Locked | 40.366287 | 0 | 0 |
16 | Locked | 40.366287 | 0 | 0 |
17 | Locked | 40.366287 | 0 | 0 |
18 | Locked | 40.366287 | 0 | 0 |
19 | Locked | 40.366287 | 0 | 0 |
20 | Locked | 40.946209 | 0 | 0 |
21 | Locked | 40.366287 | 0 | 0 |
22 | Locked | 40.946209 | 0 | 0 |
23 | Locked | 40.366287 | 0 | 0 |
24 | Locked | 40.366287 | 0 | 0 |
26 | Locked | 40.366287 | 0 | 0 |
27 | Locked | 40.946209 | 0 | 0 |
28 | Locked | 40.946209 | 0 | 0 |
29 | Locked | 40.366287 | 0 | 0 |
30 | Locked | 40.366287 | 0 | 0 |
31 | Locked | 40.366287 | 0 | 0 |
159 | 94 | 4K | 1800 | QAM4096 | 424 |
159 | Locked | 43 | 5.6 | 352633547 | 0 |
on 08-09-2023 22:15
1 | 43100000 | 48.5 | 5120 KSym/sec | QAM64 | 2 |
2 | 23600000 | 48 | 5120 KSym/sec | QAM64 | 5 |
3 | 30100000 | 48 | 5120 KSym/sec | QAM64 | 4 |
4 | 36600000 | 48.5 | 5120 KSym/sec | QAM64 | 3 |
5 | 49600000 | 49 | 5120 KSym/sec | QAM64 | 1 |
1 | ATDMA | 0 | 0 | 0 | 0 |
2 | ATDMA | 0 | 0 | 0 | 0 |
3 | ATDMA | 0 | 0 | 0 | 0 |
4 | ATDMA | 0 | 0 | 0 | 0 |
5 | ATDMA | 0 | 0 | 0 | 0 |
6 | 10.0 | 43.2 | 2K | QAM128 |
6 | OFDMA | 200 | 53.9 | 0 | 0 |
on 09-09-2023 08:47
Is this a Hub 4 that does not show any errors on the 3.0 Downstream Channels since the last software update ?
The severity of noise issue becomes clear when we look at the 3.1 Downstream Channel.
Anyone that understands data comms would look at a report of over 350 million Corrected Errors and ask the question why is there a further firmware fault prevented reporting of the Uncorrected Errors.
on 09-09-2023 09:13
Thanks for the reply. Those errors fall under “correctables” - does this imply they were not causing any issues?
either way, what are some typical causes for this and based on the above complaint - do you think this is what is causing my issues?
Thanks!
on 09-09-2023 09:16
And here’s todays BQM. Beautiful 🙃
on 11-09-2023 11:31
Hi @cf20,
Thank you for your posts and welcome to our community forums. We're here to help.
I'm so sorry to hear of your connection issues. I'd like to take a closer look at what's happening, so I'm going to send you a private message in a few moments. Please respond to this when you can and we'll proceed from there.
on 11-09-2023 19:56
I also have been checking the service status every evening. It says this message. I have been doing this daily and it never lets me progress into getting more help or an engineer!
on 11-09-2023 19:58
More BQM from today
12-09-2023 04:29 - edited 12-09-2023 04:30
@Client62 wrote:Anyone that understands data comms would look at a report of over 350 million Corrected Errors and ask the question why is there a further firmware fault prevented reporting of the Uncorrected Errors.
The high number of corrected codewords is by design (using a very powerful FEC to increase the throughput). No number is too high when looking at the OFDM channel. The number cannot be used to diagnose the problem.
