Permanent Red Light on Hub 3
Blackbusa2
Help! Everything I’ve read on here suggests my hub is overheating if there is a permanent red light on it & most likely needs replacing. How has anyone managed to get a replacement as telephoning Virgin Support gets you absolutely no where?!?
The hub still works but I’m concerned about it overheating. It’s in a well ventilated area with space around it. We’ve tried turning it off for 24 hours but still have the same issue.
1 REPLY 1
Lee_R
Hi @Blackbusa2 thanks for posting and welcome to our community.
Sorry to hear of your constant red light on your hub and for any concerns this may be causing you. I would like to help you resolve this. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
