Just joined
Periods of Broadband Bandwidth really low
I am a programmer my self and have studied networking. However after trouble shooting for a while and analysing data. My bandwidth becomes congested. Low bandwidth is normal obviously with more devices. However there are normally 3 users. The hub is not managing data correctly. One device will drop in the other will drop out. Cannot get hold of virgin media to see if there are any faults. However others are reporting in my area the same issue.
  • 24.64K
  • 1.42K
  • 3.13K
Re: Periods of Broadband Bandwidth really low
Check the service status page.
  • 11.73K
  • 915
  • 1.51K
Mike Robinson
  • 11.73K
  • 915
  • 1.51K
Can you please
Mike Robinson
