Packet loss spikes
RandomR
Hey,
I'm getting a frequent observable packet loss spikes throughout the day starting a few days ago. See the following quality monitor for reference:
5bf7e85cb60879fb0ca7a51a83965471e561bee5-22-07-2023
Can someone take a look and see if anything is wrong with my stats etc:
1282750000-0.240256 qam19
22027500001.740256 qam9
32107500001.540256 qam10
42187500001.240256 qam11
5226750000140256 qam12
62347500000.940256 qam13
72427500000.740256 qam14
82507500000.240256 qam15
9258750000040256 qam16
102667500000.240256 qam17
11274750000040256 qam18
12290750000-0.440256 qam20
13298750000-0.240256 qam21
14306750000-0.940256 qam22
15314750000-140256 qam23
16322750000-140256 qam24
17330750000-1.240256 qam25
18338750000-1.540256 qam26
19346750000-1.540256 qam27
20354750000-1.740256 qam28
21362750000-2.240256 qam29
22370750000-2.440256 qam30
23378750000-2.240256 qam31
24386750000-2.240256 qam32
1Locked40.915690
2Locked40.94430
3Locked40.34930
4Locked40.35270
5Locked40.37330
6Locked40.39740
7Locked40.38870
8Locked40.39330
9Locked40.311150
10Locked40.312650
11Locked40.311990
12Locked40.316090
13Locked40.318720
14Locked40.9202113
15Locked40.322880
16Locked40.323670
17Locked40.324540
18Locked40.927660
19Locked40.327260
20Locked40.932410
21Locked40.3309812
22Locked40.330150
23Locked40.330590
24Locked40.931600
14310000045.5512064 qam2
22360000044512064 qam5
33010000044512064 qam4
43660000045.5512064 qam3
54960000045.5512064 qam1
2ATDMA0070
3ATDMA0020
4ATDMA0010
5ATDMA0010
6 REPLIES 6
What actual issues are you experiencing on your connection?  Also, are they on just wifi connections or also on ethernet cable connections too?
Those spikes are remarkably cyclical at every four hours.  Do you have anything connecting - say on a timer -  every 4h?
Viper-t
Fibre optic
Hi I see some post rs errors on 2 channels, as well as quite a few t3 timeouts on all channels but channel 1.
What does your netlog say? Do you have any t4 timeouts and has this been happening for a while? or just one day. Have you any time sensitive packets like gaming or streaming or video calls if not you probably won't notice it. Though packet loss is a sign of network problems with the timeouts post rs errors and t3 timeouts. Someone from vm should contact you on here soon good luck.
Lee_R
Hi @RandomR thanks for getting back to us.
Sorry to hear you're having packet loss issues.  I would like to take a closer look on your behalf. I am going to send you a private message. Please keep an eye on your inbox in the top right of your screen.
Lee_R
Engineer visited - turns out to be a local area issue that has been ongoing since the 17th. Estimated fix date August 2nd.
Will keep an eye out for then
Legend
A local issue should be reported on 0800 561 0061 along with an estimate to the fix date.
Hello RandomR.
Sorry to hear about your intermittent issues and packet loss.
We do indeed have a local issue that is due to be reviewed/fixed on the 02/09/23 at 9am.
Can you pop back on here afterwards if the service is still the same.
Just quote this reference number F010845557 and we can advices on any updates.
Gareth_L
