Hello,
Since the 7th of December last year I have an issue where every night from about 20:30-23:00 my virgin connection experiences 10-20% packet loss. I have reported this since December and had one engineer replace the Hub 4 with a new Hub 4 and on Friday a Hub 5. Prior to this my connection was working fine when looking back at 6 months of BQM data.
Normally, I use modem mode with my own pFsense router, however to rule out my own equipment I have tested for multiple days on each hub change with only the virgin router, even with 0 devices connected the exact same problem persists. To note, while using the Pfsense router I can see that there is no high traffic usage and have tested this with 0 devices connected, I had also seen the issue, changed to only the virgin router in router mode and it persisted, albeit on a new public IPv4 address.
Now I am certain that there is an issue on the virgin side, however, even the engineers visiting had no mechanism to raise this problem with the virgin network and due to the limitations of OfCom as this is not 100% offline no reimbursements have been made.
There are a couple of exceptions to this behaviour, there are a handful of days where instead of stopping at 23:00 the issue continued until 23:00 the next day, this is also occurring right now. Some examples:
As a last-stitch effort to have this finally resolved I am making a post here in hopes that someone will actually look at the problem and move forward to resolve whatever issue is occurring on virgin's equipment/network.
Proof that the virgin tool recognizes the issue (I can repeat every single night during the problem):
Virgin router in router mode diagnostic test failing during the issue period (ignore wifi im using a wired connection..):
WinMTR over wired connection to cloudflare 1.1.1.1:
| WinMTR statistics |
| Host - % | Sent | Recv | Best | Avrg | Wrst | Last |
| 192.168.1.1 - 0 | 585 | 585 | 0 | 0 | 0 | 0 |
| 10.53.39.53 - 9 | 437 | 399 | 5 | 10 | 39 | 9 |
|sgyl-core-2b-xe-804-0.network.virginmedia.net - 9 | 441 | 404 | 7 | 11 | 63 | 10 |
| No response from host - 100 | 118 | 0 | 0 | 0 | 0 | 0 |
| tcma-ic-2-ae9-0.network.virginmedia.net - 8 | 453 | 419 | 13 | 16 | 37 | 13 |
| 162.158.32.254 - 9 | 441 | 404 | 13 | 20 | 53 | 15 |
| 162.158.32.9 - 9 | 446 | 410 | 13 | 17 | 49 | 15 |
| one.one.one.one - 8 | 453 | 419 | 13 | 17 | 46 | 15 |
|________________________________________________|______|______|______|______|______|______|
