Packet loss and low upload
Pitlanes
Hello. I have had problems with intermittently terrible upload speeds for a little over 12 months now with multiple engineers visiting with no resolution.
  • The issue is present over wired or wireless
  • the issue is present in modem or router mode
  • I have performed countless pin resets of the hub 4
I run the hub 4 in modem mode usually. (as above, issue persists regardless). Network is as follows
  1. hub 4 (Modem mode)
  2. ASUS AX5400
  3. Cat 7 cable (5 meters)
  4. TP-Link TL-SG105S Gigabit switch
  5. Cat 7 cable (3 meters)
  6. PC
I have previously confirmed the issue persists when plugged directly into the Hub 4 NOT in modem mode.
BQM should be attached. The packet loss times directly correlate with the near total loss of upload. Download remains fine. These periods differ when they happen day to day. Sadly, they tend to happen right where I need to be working. This is severly effecting my earnings now - I'm a full time content creator. Upload stability is vital.
The block of packet loss is where I have my networking equipment automotaically restart at 2am every day (I was fed up with being told to reboot my hub constantly).
I'd love some help.
My Broadband Ping - my virgin connection
31 REPLIES 31
Pitlanes
3.0 Downstream channels
253310000000.340.4QAM25625
61790000000.240.4QAM2566
71870000000.340.4QAM2567
81950000000.540.4QAM2568
92030000000.440.4QAM2569
102110000000.640.4QAM25610
112190000000.640.9QAM25611
122270000000.840.9QAM25612
132350000001.140.4QAM25613
142430000001.240.9QAM25614
152510000001.140.9QAM25615
16259000000140.4QAM25616
172670000001.140.4QAM25617
182750000001.340.9QAM25618
19283000000140.9QAM25619
202910000000.940.4QAM25620
212990000001.140.4QAM25621
223070000001.340.4QAM25622
233150000000.940.9QAM25623
243230000000.340.4QAM25624
263390000000.540.4QAM25626
273470000000.640.9QAM25627
283550000000.440.4QAM25628
293630000000.540.4QAM25629
303710000000.440.4QAM25630
313790000000.340.4QAM25631
323870000000.340.4QAM25632
333950000000.140.9QAM25633
34403000000-0.140.4QAM25634
35411000000-0.240.4QAM25635
36419000000-0.340.9QAM25636
25Locked40.36628700
6Locked40.36628700
7Locked40.36628700
8Locked40.36628700
9Locked40.36628700
10Locked40.36628700
11Locked40.94620900
12Locked40.94620900
13Locked40.36628700
14Locked40.94620900
15Locked40.94620900
16Locked40.36628700
17Locked40.36628700
18Locked40.94620900
19Locked40.94620900
20Locked40.36628700
21Locked40.36628700
22Locked40.36628700
23Locked40.94620900
24Locked40.36628700
26Locked40.36628700
27Locked40.94620900
28Locked40.36628700
29Locked40.36628700
30Locked40.36628700
31Locked40.36628700
32Locked40.36628700
33Locked40.94620900
34Locked40.36628700
35Locked40.36628700
36Locked40.94620900
3.1 Downstream channels
371924K3736QAM4096759
37Locked41-2.12227534471264
Pitlanes
3.0 Upstream channels
13660000042.85120 KSym/secQAM643
23010000042.55120 KSym/secQAM324
343100000435120 KSym/secQAM642
44960000043.35120 KSym/secQAM641
52360000041.85120 KSym/secQAM165
3ATDMA0000
4ATDMA0000
5ATDMA0000
3.1 Upstream channels
610.838.52KQAM128
6OFDMA22053.400
Pitlanes
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
cmreg-vmdg640-bbt076-b.cm
SFID
38858
Max Traffic Rate
1230000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
38857
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
42600
Scheduling Type
bestEffort
Pitlanes
Mon 15/05/2023
06:54:30
3No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 15/05/2023
03:53:19
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Mon 15/05/2023
01:14:46
5MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 14/05/2023
19:11:40
6US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 14/05/2023
18:39:22
Sun 14/05/2023
17:53:25
Sun 14/05/2023
10:16:00
6CM-STATUS message sent. Event Type Code: 24; Chan ID: 37; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Sun 14/05/2023
04:06:17
Sun 14/05/2023
02:02:29
Sun 14/05/2023
01:14:48
Sun 14/05/2023
00:07:26
Sat 13/05/2023
17:58:45
Sat 13/05/2023
01:14:48
Fri 12/05/2023
16:00:15
Fri 12/05/2023
15:27:54
Fri 12/05/2023
14:56:26
6US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
Fri 12/05/2023
01:14:48
Thu 11/05/2023
22:29:28
Thu 11/05/2023
10:05:18
Thu 11/05/2023
09:06:53
Thu 11/05/2023
09:02:33
Thu 11/05/2023
08:53:08
Hi @Pitlanes
I am sorry to hear of the issues with the upload speed.
I have done a system check and there was an SNR issue (signal to noise ratio) that was resolved.
I've then checked your current levels and everything is now in spec and no area issues are showing. I hope that means everything is now resolved but do let us know if not and we'll happily assist further.
John_GS
An extremely hard negative on it being fixed. BQM live in my signature.
Hello Pitlanes,
Can we please ask if there has been any improvements with the packet loss since your last post?
Gareth_L
No, I still have the intermittent issue.
Connect PC to hub in modem mode (allow power off hub 2mins) with PC in safe mode with networking to do a speed test.
Then again just a reboot of the hub may fix it for a bit.
