Hey Hiddenbanana, thanks for reaching out and sorry to hear of this issue with your services being ongoing.
We'd love to assist with this, from our latest updates it seems our network fault has cleared however we'll be able to run a few more checks with your help.
Could you please advise if you've rebooted the hub at all since the problem in the area was showing as restored?
If not, please try this and see if it helps.
In case you don't see an improvement, please perform a pin-hole reset as seen below:
Do this by holding a pen in the reset hole on the back of the Hub for 30 seconds. This will reboot the Hub and reset all Hub settings to default. If you have made any changes to the Hub's wireless settings you may need to reconnect your wireless devices to the Hub as the WiFi settings will now be back to default.
Let us know how you get on, we'll be here to assist further.
Adri - Forum Team
New around here?
