on 23-10-2023 19:00
Currently using Virgin Media Hub 3, with M250 Fibre Broadband, connected via ethernet. Every few days I have been experiencing packet loss issues that are very noticeable especially when gaming. I have checked my postcode using the automated phoneline and the app; there are apparently no issues.
I have just now set up a BQM so it will only have the past hour or so of data but here it is:
I have been getting the following network log issues:
Downstream (maybe power issues?):
Upstream (32 qam?):
Real Speed Test:
If you have any solutions or need more information please ask.
Thank you,
on 23-10-2023 19:17
All Downstream power levels are far too high.
All Upstream power levels are too low, and one channel is degraded to QAM 32.
Has a 10dB Wideband attenuator been removed from the connection to the Hub ?
Downstream Power Levels of -7 to +7 dBmV are preferred, +10dBmV is the max acceptable, with a SNR of 33dB or higher across all DOCSIS 3.0 channels. Rising error counts across many channels is a current service noise fault.
Upstream Power Levels of 35 to 49 dBmV are preferred, with QAM 64 Modulation mode across all four to six DOCSIS 3.0 channels. Seeing QAM 32/16/QPSK is a current service noise fault. Seeing less than four DOCSIS 3.0 channels is usually a signal level fault.
on 23-10-2023 19:25
Hi, Thanks for replying
not sure if this is what you are referring to?
thanks for the help
on 26-10-2023 09:49
Hello RM04/
Thanks for your post and welcome to our Community.
Sorry to hear about the packet loss.
Looking at your pictures I would say this is a self installation and the power levels need tweaking a bit.
I did run a test on your hub and can see both upstream and downstream levels are out.
It would need an engineer to attend, which I can arrange from here.
If you can check the Logo top right of your screen that would be great.
Gareth_L
on 30-10-2023 12:53
Hi Gareth_L,
I still haven't received a reply from you since Thursday. Please can someone else from the forum team take over this case or bump Gareth_L. I need to get this packet loss fixed as soon as possible.
