Message 1 of 7
Packet Loss for over two weeks
I've had extreme packet loss and latency issues for the past two weeks, I've had an engineer out already and they just changed some cables but it's still the same. I was wondering if anyone could help? The same issues arises with all devices connected Wi-Fi and an ethernet cable and renders the broadband useless for majority of the day.
I do have a monitor below. Thank you
Message 2 of 7
Re: Packet Loss for over two weeks
I have also reset the Superhub 3 router before.
  • 11.7K
  • 913
  • 1.51K
Message 3 of 7
If nothing is showing try phoning 0800 561 0061, this will tell you of more local issues that may be affecting your district. Be aware that it isn't a manned line.
Go round all the accessible internal and external co-ax connections and ensure that they are finger tight.
If everything above is OK we need do some more troubleshooting; to start with …
Then
Can you please
Mike Robinson
Message 4 of 7
My BQM
1402750000-138256 qam30
2202750000-338256 qam9
3210750000-4.438256 qam10
4218750000-2.238256 qam11
5226750000-4.737256 qam12
6234750000-2.240256 qam13
7242750000-4.538256 qam14
8250750000-3.238256 qam15
9258750000-5.937256 qam16
10266750000-337256 qam17
11274750000-438256 qam18
12282750000-238256 qam19
13290750000-1.938256 qam20
14298750000-138256 qam21
15306750000-0.238256 qam22
16314750000-238256 qam23
17322750000038256 qam24
18330750000-1.738256 qam25
19370750000-0.240256 qam26
20378750000-1.538256 qam27
21386750000040256 qam28
22394750000-1.738256 qam29
23410750000-1.538256 qam31
24418750000040256 qam32
1Locked38.950
2Locked38.6300
3Locked38.97730
4Locked38.930
5Locked37.638211
6Locked40.3170
7Locked38.9130
8Locked38.630
9Locked37.6593
10Locked37.67035
11Locked38.600
12Locked38.690
13Locked38.900
14Locked38.910
15Locked38.900
16Locked38.990
17Locked38.600
18Locked38.670
19Locked40.900
20Locked38.910
21Locked40.310
22Locked38.900
23Locked38.900
24Locked40.360
1394000005.4512032 qam10
2462000005.029512032 qam9
Message 5 of 7
31/10/2020 14:08:3noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 14:07:48Warning!LAN login FAILED : Incorrect Username / Password / ConnectionType;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:58:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:58:8criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:57:22criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:57:22criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:56:56noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:56:30criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:56:29criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:55:52noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:55:42criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:55:42criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:55:26noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:54:50criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:54:50criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:54:8criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:54:8criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:53:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:53:10criticalUnicast Ranging Received Abort Response - initializing MAC;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
31/10/2020 13:52:23criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
  • 11.7K
  • 913
  • 1.51K
Message 6 of 7
Your >> BQM << is a mess and this is reflected in the Network Logs.
You only have two Upstream Channels, we would expect to see four. Of those two that you do have one power level is too high and one close to max power and both are running at 32 QAM and these should be at 64 QAM.
This will need an engineer to put right.
You can either phone in (08:00 is the best time) or wait on here for a few days (6 to 7 days average) until one of the VM Forum Staff comes along.
Mike Robinson
  • 1.88K
  • 95
  • 175
Message 7 of 7
Hi Derels.  Thanks for posting and welcome to our community.
I am sorry you're having issues with your connection and power levels.  I would like to take a closer look on your behalf.  To enable me to do so, I am going to send you a private message.  Please look out for the purple envelope in the top right of your screen.
Lee_R
