novo78
  • 12
Message 1 of 11
Packet Loss and Connection Drop Outs
Hello, I am hoping someone can help.
Over the last few months, mainly since my services were upgraded to 1GB, I have been having a lot of packet loss and random connection drop outs. This is a problem when streaming as it causes the stream to drop out altogether.
I've tried talking to the tech support representatives via phone and via chat but I am getting bored of being told that my issue is related to either my Superhub being in Modem Mode, or being told my Router Firmware is outdated .. an update being sent (version never changes) and that I should call back in 24 hours .. (Obvious fob off technique).
I have tried:
  • Checking all connections are tight.
  • Restarting and power cycling my superhub many times
  • Restoring factory defaults
  • Running in Router Mode
  • Replacing every network cable on network
The network issues occur on both wired and wireless connections.
The below graphic shows a large amount of packet loss over the last 24 hours.
Last 24 HoursLast 24 Hours
novo78
  • 12
Message 2 of 11
Re: Packet Loss and Connection Drop Outs
Downstream:
3.0 Downstream channels
Channel
Frequency (Hz)
Power (dBmV)
SNR (dB)
Modulation
Channel ID
25
331000000
-0.200001
38.605377
QAM256
25
1
139000000
1.900002
38.605377
QAM256
1
2
147000000
1.599998
38.983261
QAM256
2
3
155000000
1.099998
38.983261
QAM256
3
4
163000000
0.900002
38.983261
QAM256
4
5
171000000
-0.599998
38.605377
QAM256
5
6
179000000
0.900002
38.983261
QAM256
6
7
187000000
1.200001
38.983261
QAM256
7
8
195000000
1.299999
39.397190
QAM256
8
9
203000000
1.000000
38.983261
QAM256
9
10
211000000
0.900002
38.983261
QAM256
10
11
219000000
-0.099998
38.983261
QAM256
11
12
227000000
0.299999
38.605377
QAM256
12
13
235000000
-0.200001
38.983261
QAM256
13
14
243000000
-0.200001
38.983261
QAM256
14
15
251000000
-0.299999
38.983261
QAM256
15
16
259000000
0.099998
38.605377
QAM256
16
17
267000000
0.299999
38.605377
QAM256
17
18
275000000
-0.299999
38.605377
QAM256
18
19
283000000
-0.099998
38.983261
QAM256
19
20
291000000
-0.099998
38.983261
QAM256
20
21
299000000
0.000000
38.983261
QAM256
21
22
307000000
0.099998
38.983261
QAM256
22
23
315000000
0.000000
38.605377
QAM256
23
24
323000000
0.099998
38.605377
QAM256
24
26
339000000
-0.400002
38.605377
QAM256
26
27
347000000
-1.400002
37.636276
QAM256
27
28
355000000
-2.700001
37.636276
QAM256
28
29
363000000
-1.400002
38.605377
QAM256
29
30
371000000
-0.799999
38.605377
QAM256
30
31
379000000
-0.099998
38.983261
QAM256
31
Channel
Lock Status
RxMER (dB)
Pre RS Errors
Post RS Errors
25
Locked
38.605377
0
0
1
Locked
38.605377
0
0
2
Locked
38.983261
0
0
3
Locked
38.983261
0
0
4
Locked
38.983261
0
0
5
Locked
38.605377
0
0
6
Locked
38.983261
0
0
7
Locked
38.983261
0
0
8
Locked
39.397190
0
0
9
Locked
38.983261
0
0
10
Locked
38.983261
0
0
11
Locked
38.983261
0
0
12
Locked
38.605377
0
0
13
Locked
38.983261
0
0
14
Locked
38.983261
0
0
15
Locked
38.983261
0
0
16
Locked
38.605377
0
0
17
Locked
38.605377
0
0
18
Locked
38.605377
0
0
19
Locked
38.983261
0
0
20
Locked
38.983261
0
0
21
Locked
38.983261
0
0
22
Locked
38.983261
0
0
23
Locked
38.605377
0
0
24
Locked
38.605377
0
0
26
Locked
38.605377
0
0
27
Locked
37.636276
0
0
28
Locked
37.636276
0
0
29
Locked
38.605377
0
0
30
Locked
38.605377
0
0
31
Locked
38.983261
0
0
3.1 Downstream channels
Channel
Channel Width (MHz)
FFT Type
Number of Active Subcarriers
Modulation (Active Profile)
First Active Subcarrier (Hz)
159
96
4K
1840
QAM4096
424
Channel ID
Lock Status
RxMER Data (dB)
PLC Power (dBmV)
Correcteds (Active Profile)
Uncorrectables (Active Profile)
159
Locked
41
0.4
390745190
9071
novo78
  • 12
Message 3 of 11
Upstream:
3.0 Upstream channels
Channel
Frequency (Hz)
Power (dBmV)
Symbol Rate (ksps)
Modulation
Channel ID
1
36600000
52.520599
5120 KSym/sec
64QAM
3
2
23600000
52.520599
5120 KSym/sec
32QAM
5
3
30100000
52.520599
5120 KSym/sec
64QAM
4
4
43100000
52.020599
5120 KSym/sec
64QAM
2
5
49600000
52.520599
5120 KSym/sec
64QAM
1
Channel
Channel Type
T1 Timeouts
T2 Timeouts
T3 Timeouts
T4 Timeouts
1
US_TYPE_ATDMA
0
0
0
0
2
US_TYPE_ATDMA
0
0
0
0
3
US_TYPE_ATDMA
0
0
0
0
4
US_TYPE_ATDMA
0
0
0
0
5
US_TYPE_ATDMA
0
0
0
0
3.1 Upstream channels
Channel
Channel Width (MHz)
Power (dBmV)
FFT Type
Modulation
6
10.0
45.5
2K
QAM8
Channel
Channel Type
T3 Timeouts
T4 Timeouts
6
OFDMA
200
53.9
2
0
General Config:
General Configuration
Network access
true
Maximum Number of CPEs
1
Baseline Privacy
true
DOCSIS Mode
3.1
Config file
54k;fg87dsfd;kfoA,.iyewrkldJK
SFID
514
Max Traffic Rate
1200000450
Max Traffic Burst
42600
Min Traffic Rate
0
Primary Upstream Service Flow
SFID
513
Max Traffic Rate
55000270
Max Traffic Burst
42600
Min Traffic Rate
0
Max Concatenated Burst
16320
Scheduling Type
bestEffort
Last 48 hours of NetworkLog:
Time
Priority
Description
Wed Feb
15
6
CM-STATUS message sent. Event Type Code: 5; Chan ID: 25; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Wed Feb
15
6
US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Wed Feb
15
6
Wed Feb
15
6
US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Wed Feb
15
6
Wed Feb
15
6
US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Wed Feb
15
6
Wed Feb
15
6
Wed Feb
15
6
Wed Feb
15
6
Tue Feb
14
6
CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 1.;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Tue Feb
14
6
Tue Feb
14
6
Tue Feb
14
6
Tue Feb
14
6
Tue Feb
14
6
Tue Feb
14
3
No Ranging Response received - T3 time-out;CM-MAC=xx:xx:xx:xx:xx:xx;CMTS-MAC=xx:xx:xx:xx:xx:xx;CM-QOS=1.1;CM-VER=3.1;
Tue Feb
14
6
Tue Feb
14
3
Tue Feb
14
6
Tue Feb
14
3
  • 13.9K
  • 1.08K
  • 2.81K
Message 4 of 11
Stats are fine except one upstream is 32 instead of 64 QAM.
Check with Area faults on 0800 561 0061 If you have a VM landline 150 this goes down to post code level. You could also try the web page status, but this is not recommended as it only covers issues that affect a very large number of customers.
novo78
  • 12
Message 5 of 11
Thanks for the reply, I tried calling the service status line. It reported there are no issues in my area at this time.
I've used the service status page a few times.
I've had loads of packet loss and drop outs today around 2pm...
Could this be related to that upstream channel being 32 instead of 64 QAM?
Thanks in advance.
novo78
  • 12
Message 6 of 11
Another day full of packet loss..
Surely there has to be a fix for this?
John_GS
  • 15.7K
  • 798
  • 1.46K
Message 7 of 11
Hi @novo78
Sorry for the service issues you're having.
I have done a system check and no issues are showing here - however, please can you pop the hub in router mode for me as there are a few checks I need to also do.
The modulation has gone back to what it should be as well which is good news.
Best wishes,
John_GS
novo78
  • 12
Message 8 of 11
Hi John,
I've changed the router back to Router Mode. Please let me know when I can switch back to Modem Mode.
I restarted the superhub on Thursday and the packet loss seemed to stop for a couple of days, I'm guessing this was raround the same time you looked on Friday.
Packet loss issues have returned again.
I just restarted the router to put it back in to router mode, so I suspect it won't show packet loss for a while
novo78
  • 12
Message 9 of 11
I've left it in Router mode for 24 hours, I need to switch it back to Modem mode again.
Hopefully you collect the information you needed.
Matthew_ML
  • 3.6K
  • 132
  • 242
Message 10 of 11
Thank you for doing this novo78.
I have run some tests from my end and I would like to look into this further so I am going to send you a PM.
Please look out for the purple envelope. Thanks
Matt - Forum Team
New around here?
