on 03-04-2023 20:18
I noticed that my PS5 was downloading super slow and even signed me out so I checked and I saw that the connection is 2.4ghz. I don't know if this is the cause of the slow downloads. When I check on PS5 I'm getting 20mbps download speed. My connection is speed is 200mbps.
Now, the obvious is to change to my 5ghz connection but it will not connect to it. It says 'connection might be weak'. The virgin app say wifi is good in my room.
I've tried everything to fix, including calling PlayStation who asked me to open ports in the router settings. I did that and, surprise surprise that did f all.
I'm wondering does anyone here have a suggestion I could try? Or I'm I stuck with a slow PS5 connection.
I have a Xbox which gets very fast speeds. The xbox and PS5 are next to each other upstairs while the router is downstairs. My internet works fines everywhere except this PS5 issue. I have a Hub 5.
I've noticed a few threads about Ps5 on here so maybe it's a common issue that can't be fixed? Either way, any help would be appreciated.
on 04-04-2023 10:42
Have you used WiFi Pausing and blocked PS5's 5Ghz WiFi connection ?
on 04-04-2023 13:17
I checked that in the app and I have nothing paused.
on 04-04-2023 13:54
Totally forget the VM Connect app is the number one cause of blocked WiFi connections.
Disable MAC filtering to re-enable Paused devices
Login to the Hub's menus at http://192.168.0.1
1) Advanced settings >>> Wireless >>> Security
1.1) then set Wireless MAC Filtering to Disabled
1.2) "Apply changes"
2) Advanced settings >>> Security >>> MAC Filtering
2.1) then delete all entries in the MAC filter list
2.2 Enable Always on
2.3) "Apply changes"
