on 19-06-2023 11:41
Hello, we came home last night after a weekend away to find that our router box was flashing red and we had no WiFi. After talking to downstairs neighbour, it seems they are having the same problem and, when they investigated further, they noticed that the wires by the meters to the right of the building seem to have been completely cut over the weekend.
I’m due a call back from Virgin Media, but would love any advice about what to do next in order to get this sorted as quickly as possible. Will a VM engineer be able to fix this?
on 19-06-2023 13:18
Fault will be fixed by VM technician for free.
The primary place to report faults or for service requests is Customer Services on 0345 454 1111/150 if you have a VM landline or wait two or three days for a VM staff member to get to your post.
on 19-06-2023 13:51
The 2 black wires that appear to be cut are just to the phone sockets which aren't your broadband fibre cables. The other 2 black wires that are thicker are your broadband cables which don't appear to be cut . Find the thicker black cable which is coming from the ground and connect it at the top exactly where someone has screwed in the brown one . That brown one shouldn't even be there . Then find the cable that leads from your home and out along the wall which should be also black the and connect it to the bottom . Make sure your not connecting your neighbours cable . They'll have their own separate box connector .
on 19-06-2023 14:20
Hmm bk . If the brown cable coming from the ground is yours and it's still in use but they're very old type then its fine where it is . Disconnect all the wires at the bottom then find the cable leading out off your home and connect it at the bottom .
on 19-06-2023 14:40
Thank you for your reply! We have two black wires coming out from our living room (top floor flat) - one of these appears to still be connected and the other has been severed at the bottom (see pic). There are two places in the front garden where there are wires coming out of the ground and both are completely severed and not connectable - not sure which is for which. Do you think the severed one could be our internet cable?
We've been given an outside engineer (VM) appointment for next Wednesday but I'm not sure whether they'll be able to do the work and my neighbours are with Sky and also affected. Do you know if there are any ways we could get someone out sooner? Thank you!
on 19-06-2023 16:11
The wire your holding in the first picture is the phone wire that's nothing to do with your broadband you can ignore that if you don't have a landline. Hopefully the second black wire coming down outside of your flat isn't severed. This should only be wire connected at the bottom of that little metal box connection with 3 ports . Now you'll need to identify your 2 cables coming out from the ground which are yours. One will be thick one will be thin . Ignore the thin one. If thickest one is severed and it's showing a white insulation inside around a single copper wire in the middle you'll need a technician or someone you can fix it . If that cable isn't severed then connect the thick cable at the top of that little metal box where there's only one port at the top . .
on 19-06-2023 16:15
Btw I'm not from Virgin Media . I just had fun having to mess with those cables to many times .
on 19-06-2023 16:27
Haha thank you! Managed to get a cancellation appointment for this Weds so will wait for them to come rather than trying to handle live wires myself... thanks again for the advice!
on 19-06-2023 16:56
That metal splitter should be mounted in a box, not just left on the ground.
on 19-06-2023 17:26
Yes . But looking at the pictures this was deliberately done .
