UserSE15
  • 9
Message 1 of 8
Our virgin Hub 4 is dead, how fast can u send a replacement as we all wfh ?
HELP!  Our virgin Hub 4 is dead, how fast can u send a replacement as we are all wfh ?
Had a power cut that lasted around 10-15 mins and it seems to have killed our hub 4 when the power came back. We just get a solid white light and no internet connection.
-tony-
  • 16.93K
  • 1.32K
  • 4K
Message 2 of 8
Re: Our virgin Hub 4 is dead, how fast can u send a replacement as we all wfh ?
so its not dead and a solid white band suggests its connected to VM system - so how are you trying to connect - if wifi had you changed your ssid or passwords - it may be that the power cut set it back to default in which case you will not be able to connect
if you had not changed the passwords od ssid then the opposite may have happened and they are corrupt
a full reset it the 1st thing to try - hold the button a good 30sec and then some - that will set the ssid and passwords back to default - from there see what happens
if you have cable connections then again the reset is the 1st thing to try
____________________
Tony
  • 16.3K
  • 711
  • 1.6K
Message 3 of 8
Ports might not work even with solid white light.
UserSE15
  • 9
Message 4 of 8
@tony - tried the reset and even the old school power off and on… nothing…
-tony-
  • 16.93K
  • 1.32K
  • 4K
Message 5 of 8
ok - back to basics - lets define nothing
do you have any wired devices - do they work - what do you see with wifi - any ssid's show on a pc or phone
log into hub3 or hub4- 192.168.0.1 [or 192.168.100.1 if in modem mode] - DON'T SIGN IN, click - click router status [centre of screen] - and post the downstream and upstream figures - to see those press on the grey buttons/boxes labelled - upstream - downstream
Tony
UserSE15
  • 9
Message 6 of 8
Hi Tony,
Nothing as in no internet at all 😞
-tony-
  • 16.93K
  • 1.32K
  • 4K
Message 7 of 8
i think you need to ring and book a tech - 150 or 0345 454 1111 - VM will get to the thread - your initial thinking may be correct but the white ring light says its working so the hub may be faulty or it may be elsewhere
will flag the thread
Tony
John_GS
  • 9.19K
  • 494
  • 831
Message 8 of 8
Hi UserSE15
Thanks for posting. My apologies for the broadband issue with the router.
I am going to PM you to get the address details and we can assist further
Best,
John_GS
