Orange/yellow light on hub 3.0
anne329
Hi, I've joined virgin on the 16th august and self installed my new hub 3. All seems to be fine except:
The base light is solid amber/yellow  not the expected white as it says in the book i have reset the hub twice and it has not solved the issue and in some rooms it doesn't seem to want to connect to the wifi or its very poor signal bars i've ran tests no issue in my area what does the light mean is there an issue with the hub i was sent  ?hub.png
2 REPLIES 2
Ignore it.  Its just the 1p LED fading with age.  There are no "new" Hub3's - they are issuing old "refurbished" units to costomers.   The LED is not changed.
The poor wifi is another issue - see this older post...
______________
On a Hub3, you could first try separating the SSID's of the 2.4 and 5 GHz wifi bands by renaming them in the settings At the same time switch off "channel optimisation/Smart wifi” and “ apply and save the settings. All wifi devices will now need reconnecting to the best SSID at each location. Also use a wifi scanning App to find the best wifi channels to use (just select and use channels 1,6,11 on 2.4GHz) - this often helps Hub users get better wifi performance - so its worth trying - but its still no substitute for getting better kit 🙂
To address the wifi issues, VM now supply “wifi Pods” (no longer doing cheap and cheerless and poor value “boosters”). However, their Pods are only free to customers on the 1GB, Volt (or old Ultimate Oomph) packages - is that you? If so they are worth trying - they should work for you. VM Wifi is now “guaranteed” to 30 Mbps/room it’s now called… Wifi Max
You call 0800 064 3850 to order the first one after scanning for blackspots using the connect App.- or just wait here for a VM person to respond in a day or two and they will sort the first one for you. If you do call dont get fobbed off by the offshore CS agents' saying you aren’t eligible - you are - it is clearly stated on the webpage.
If not free to you… you will be charged £8/month for up to 3 pods (note - BT charge £10/mo for their whole home wifi solution). It’s a simple solution and should work for you. However, you would soon pay off that cost by buying your own wireless solution that will be yours to own and use forever, although the VM Pods should be a simpler option.
If you do want to invest in better equipment, you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point, (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3).
£40-100 (that’s ~4->12 months of Max Pod rental) should sort it for most customers with an average property and usage. Spend more for additional advanced“features” - if required.
Legend
Colours are very subjective.
However the picture shows a Hub 3 light that is identical our Hub 3 which is working fine.
